It sounds like the fan may not be operating or the air path is plugged up. I think what is happening is you are running the compressor on high head causing it the thermal relay to drop out.
doesn't sound good sounds , the compressor is bad .. you might want to check if it has a gfic. i could be bad, i would cut it out and try it without before i replaced a gfic
Sounds like the fan quit....could be the board or the fan motor ...check for power at the motor...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Sounds like this unit developed a freon leak and that will make it run hot like that...cheaper to replace it then to repair... There are many reasons for a dehumidifier to not work or collect water. Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier.
Check the relative humidity in the room or space where you are operating the dehumidifier. Damp feeling and actual humidity level are two separated items. Humidifiers will run for a few minutes until it is signaled that the humidity is already low enough and then shut down.
