Samsung WE356A5W Washer/Dryer Laundry Pedestal Logo
Posted on Oct 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung dryer keeps running. will say 15 minutes left then say 1 hour left, the get to 6 minutes left then go to 45 minutes left....
Anonymous
Level 3:
  • Master 715 Answers
  • Posted on Oct 07, 2009
Anonymous
Master
Level 3:
Answers
715
Questions
Helped
151141
Points
1931
  • seounghun May 29, 2011
    i have the same problem. We replaced Timer, clean the moisture sensor bars and clean the venting system...but the problem stays the same
My dryer wont run the time i enter if it says 1:40 it barely runs 15 min why?
try entering 1:2 as it probably means that 1:4 is 15 minutes as the time increments is 1/4 hours in minutes
Jan 04, 2017 • Dryers
I have a LG dryer model DLE5932W that will not shut off on its own
will it shut off if you run it on time only mode?
Aug 31, 2016 • LG Dryers
How long does it take to drive from Montana to Las Vegas
13 hours, 21 minutes
The driving time from Great Falls Montana to Las Vegas Nevada is
25645215-namh4xdyvtmbnfjkezl10utl-2-0.jpg 410-412 5th Avenue South, Great Falls, MT 59405, USA
988 mi - about 13 hours 27 mins
1. Head east on 5th Ave S
223 ft
2. Turn right at the 1st cross street onto 5th St S
0.4 mi
3. Turn right onto I-15BUS/MT-200 W/US-89 N/10th Ave S
Continue to follow I-15BUS/MT-200 W/US-89 N
2.0 mi
4. Keep left at the fork, follow signs for I-15 S/Helena and merge onto I-15 S
148 mi
5. Take the exit onto I-15 S/I-90 W toward Butte
8.0 mi
6. Take exit 121 for I-15 S toward Dillon/Idaho Falls
0.7 mi
7. Continue onto I-15 S
Passing through Idaho
Entering Utah
377 mi
8. Keep left at the fork to stay on I-15 S
35.7 mi
9. Keep left at the fork to stay on I-15 S
Passing through Arizona
Entering Nevada
415 mi
10. Take exit 44 for Washington Avenue toward D Street/City Parkway
0.3 mi
11. Turn left onto D St
0.2 mi
12. Turn left onto W Bonanza Rd
Destination will be on the left
0.6 mi
500-546 East Bonanza Road, Las Vegas, NV 89101, USA
Dryer completely shuts off after about 15 minutes. Cannot turn the dryer back on for about an after
SORRY TO HAVE TO TELL YOU BUT Dryer runs then shuts down wont start up for an hour:
Bad motor windings
Aug 31, 2014 • Dryers
Samsung dv331ag works fine for 30 minutes then everything goes black after 1 hour works fine again for only 30 minutes
sorry to have to inform you sounds like a bad motor windings? overheating after 20 minutes then shutting down after cool down about an hour it starts agin. A bad venting problem may have caused it?
I have a Samsung DV431AGP. Dryer never stops clothes are done and just keeps running. Even in the timed mode. Starts up, drys clothes, and 1 hour later still has same amount of minutes left.
the cause of this is a bad timer switch it is the switch directly under the knob you turn to set the time on the dryer.You can purchase a new one on amazon or buy one from tribbles in timonium.
SAMSUNG --MODEL# DV3C6BEW/XAA NOW COMPLETELY SHUT OFF. CAN NOT TURN ON OFR OFF EARLIER -NOT HEATING PROPERLY, TAKES A WHOLE DAY TO DRY CLOTH.. IF YOU SET DRYER TO 60 MINUTES, IN 15 MINUTES, IT...
dryer has a restriction in the venting process; disconnect vent hose and run dryer should work, if not then you will need to take apart and clean out all the lint inside the dryer.
washer:
http://www.ehow.com/how_4910369_troubleshoot-washing-machine.html
Top Samsung Washing Machines Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
