Canon PowerShot A630 Digital Camera Logo
Posted on Oct 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
A630 Indoor pictures are too dark in Auto, Flash
Canon A630 Indoor pictures are too dark in Auto, Flash seems to work but picture looks like no-flash . I have two of these cameras, both have this malfunction which occured several months apart
Terry Herrera
Level 2:
Scholar:
  • Expert 109 Answers
  • Posted on Oct 07, 2009
Terry Herrera
Expert
Level 2:
Scholar:
Answers
109
Questions
0
Helped
36080
Points
323
Try using night mode indoors. otherwise, simply get into setup and go back to factory settings, and use AUTO mode. hope it helps
5 Related Answers
Anonymous
  • 148 Answers
  • Posted on Dec 24, 2007
SOURCE: CANON Rebel RTI Outdoor pictures are dark
learning to use light metering correctly can have its challenge.
the manual will guide you on how to set up to read light from the subject. spot metering a dark area will cause general overexposure, or a washed out look. spot metering a bright area will cause a dark image. if you are on spot meter and shoot two people standing together against a bright lit background, your meter will see between them if they are centered, and read all that bright background, setting the camera to a less sensitive combination of aperture / shutter speed, resulting in a dark image. use field averaging meter setting and be sure you are metering the subject and not the background. try shooting a wall that is fairly clear of other colors and uniform it light hitting it, you should have a correctly exposed image. since it works in other modes (at least 1, anyway) then it is unlikely you have an exposure compensation issue. that is the only other non defect issue that would cause your problem.
once you confirm that you have these settings correct and still get a dark image, its time to have it serviced.
good luck
mark
Anonymous
  • Posted on Apr 02, 2008
SOURCE: Nikon D40 Image Darkness
turns out that the camera is faulty and I've sent it for repairs to get a new part
Anonymous
  • Posted on Jun 29, 2009
SOURCE: Canon powershot A630 blinking flash graphic
You have to unscrew the left side of the camera (if you're looking at the back of the camera, the side that is right beside the flash). Then, at the very top, with a tiny screw driver, just gently tap the black flash compartment and it should work after that. I've had the flash problem twice in the past year and both times I got it to work again by taping on it. Hope it helps!
Anonymous
  • 2702 Answers
  • Posted on Oct 22, 2009
SOURCE: the flash on my canon powershot a630 stopped
in a word you dont!!! drop it into the shop they may fix it at price,
but if you open it up the flash capacitor inside could realy bite you
or,,, maybe even kill you??? my pall once tuched this capacitor and he had his arm in a sling for a month, the jolt he got off it "riped his are mussels to bits!" he was very lucky,,, he lived!!! be warned!!!
Anonymous
  • 4 Answers
  • Posted on Apr 17, 2010
SOURCE: how do you turn off the flash on a canon a630
Press the button at the back of the camera designated with a lightning symbol. When you pressed it once, it will give you an option for lightning bolt which means flash ON and to turn it off, select the lightning bold with line through it.
2answers
I have a Canon Power Shot A720. Outdoor photos are beautiful. Indoor photos are always grainy/blurry...a lot of noise. I have tried the ISP feature but there are only two choices... 1. Auto or 2....
Hi Usually outdoor picture are good within small compact camera. They designed like that. But now your unit just have flash pcb defective. When flash function work, your picture will be good indoor. Regarding your flash unit would be brown fuse or replacement of flash unit. It is 50 and 50 chance. Your local repair shop would charge around $35 to 95 depend on what they really want to charge. Thanks and best regard!
2helpful
How do I turn off the flash for the canon powershot a630?
First of all, the flash can not be turned off in "Auto" mode. You can turn it off in any mode other than Auto. Would recommend Program "P" mode, which is very similar to Auto, but allows you to modify certain minor items such as flash and white balance.
Rotate your mode dial to "P", then press the button on the back with the "lightning bolt" icon. Press until the lightning bolt with a slash shows up on your LCD screen. The flash is now turned off in Program mode. Try taking a picture.
Remember, if in low light conditions you'll need to keep the camera extra steady without flash to get a clear picture. Recommend placing the camera on a table or chair (or even better, use a tripod), then using its autotimer to snap the picture.
Same as posted - picture is way too dark when using flash. Help!
Try a camera reset. Go into the setup menu and scroll to "reset" and follow the on-screen instructions.
2answers
Pictures too Dark
Try resetting the camera. Go into the setup menu and find "reset".
Dark pictures
check out for the ISO settings !!! it wil help u out in taking bright pictures
11helpful
1helpful
No flash in auto mode
Try a mode other than auto, and turn off the flash. Then try taking a picture. Did it work? If so, then your flash is either burned out, or the flash safety circuit thinks that the camera is open. If the flash is burned out, then professional repair is required, as a flash change-out is not trivial (Call 1-800-OK-CANON). However you mention the flash works sometimes, so a totally burned out flash tube is unlikely.
It's more likely to be only a break or bad connection in the safety circuit. Many Canon cameras use some of the screws in the camera case to serve as a means of detecting if the case is open (and thus disables the flash to prevent shock). Examine all the screws around the perimeter of your case. Are they all there and tight? If not, tighten loose screws and try moving and replacing any missing screws with one of the others that are still there.
2answers
Dark image....even using flash.
go to the menu & open setting file.properly check the settings of auto mode
2helpful
The problem here is likely the auto setting. Put it to sunny, clear day instead of indoor picture and you should be ok. Also, point it at neutral colored objects when you take the picture and allow it time to adjust by holding the button in partway before depressing it fully.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
