Lenovo 3000 N200 Notebook Logo
Posted on Nov 11, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lenovo 3000 N200 Fan Doesn't work
My computer and everything else works but the fan does not start i opened the "hood" and tried the fn on other computer and it worked then i cheked the voltage on the conectors of the fan on the motherbord and it's alright so i think that the probleme is with the softwere but i dont know what it is/ i have windows 7 if it maters..
Adimurugan.V
Level 2:
  • Expert 119 Answers
  • Posted on Nov 13, 2017
Adimurugan.V
Expert
Level 2:
Answers
119
Questions
0
Helped
61243
Points
266
Replace the fan. The coil in the fan may be damaged.
5 Related Answers
Anonymous
  • 42 Answers
  • Posted on Feb 22, 2009
SOURCE: lenovo 3000 n200 laptop
the battery is on the main motherboard. to get to it:
1) remove all power supplies
2) remove the keyboard
3) remove the screws on the bottom, leaving the covers and the one that's holding the optical drive (there's an on/off button engravement nex to it)
4) flip it over and remove the cover around the keyboard, be careful with the connection cables, I think some need to be disconected
* you might need to remove the screen unit, too, but i don't think it's nececerry. also, the lenovo manual on the website might be helpful.
Anonymous
  • 12 Answers
  • Posted on May 11, 2009
SOURCE: i need the webcam driver for Lenovo 3000 N200 0769 A63 webcam please help
try getting the driver from a website called softpedia or rapidshare
Anonymous
  • 57 Answers
  • Posted on Sep 15, 2009
SOURCE: drivers Lenovo 3000 N200 mod?le 0769-A43
Enter Here for all your drivers for lenovo 3000 n200! Rate me for this! Thanks!
Anonymous
  • Posted on Feb 01, 2010
SOURCE: Require Audio Driver for Lenovo 3000 N200 type 769 dual-core
I purchased a used lenovo laptop 3000 n200 0769 intel centrino core 2 *** 2\r\nwithout any driver for audio, network, camera, vedio, and other drivers...
from where can I load them
pls. help me
Anonymous
  • 83 Answers
  • Posted on Apr 14, 2010
SOURCE: fan will not work (lenovo 3000 n200 0769)
Check the Vendor Site for A bios update.
Hi I have Lenovo 3000 n200. When I try to turn it on I hear fan noise, DvD burner works, dark screen, nothing shows on screen and after that everything is silent. I did hard reset etc but no use. I...
On the back of the laptop there should be a compartment.Open it a find the RAM sticks.If you have 2 sticks,remove one and try to run it with only one and repeat the same process with the other stick.If you have an extra RAM please insert a it and run the laptop.
How to switch on/of wifi in lenovo 3000 N200
Welcome to Fixya
Wifi switch is usually located at the side or at the front of the laptop. You may try to enable/disable the webcam by pressing Fn + Esc key.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
2helpful
Sir i could not get webcam driver for my lenovo 3000 n200 for window 7.. please help sir
you may need to activate webcam by pressing fn + esc (or check the key combination for webcam in user manuals)
also make sure your function keys working, if not re-install power management.
My lenovo 3000 N200 laptop shut down and will not start. I have unplugged the battery and power cable, I have cleaned the fan. No lights are appearing, nothing is happening when I press the power...
this could be a couple of things wrong.
1.i would try another power cable first.
2,can you hear if the fan is trying to run if not then you may need to take it to some one to have a look at it for you.
Hi, I have a problem with a fan of my lenovo 3000 n200. Don't start.I have windows Xp and i have do a upgrade of bios. Thank Andrea
the fan problem is due to hardware problem. check the fan connection. it is not adviced to open a laptop because it void warrenty. so better to take to a service centre.
Fan will not work (lenovo 3000 n200 0769)
Same problem
The issue is, the motherboard is faulty. You will need a systems engineer to look at it. Some chips are burnt and should be replaced. The only other alternative is to replace the entire motherboard.
2answers
Laptop fan spin for 2 second and display not show
You must veryfi the CPU and try without battery or try it without charger with a already charged battery! This must work!
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
