Epson Stylus Photo R340 InkJet Printer Logo
Posted on Dec 24, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Epson Photo R265 Lines every 2.5 cm
All my prints are coming out with horizontal lines across them every 2.5 cm. The lines aren't the white ones that would indicae the need for head cleaning. Nevertheless I have cleaned the heads and performed print head alignment but the problem persists. Any advice?
same problem epson stylus photo R 340
stu
Pedro
Level 2:
  • Expert 233 Answers
  • Posted on Jan 09, 2008
Pedro
Expert
Level 2:
Answers
233
Questions
Helped
133996
Points
583
Clogged nozzle, run the clean head then test page in this order at least 5 times in a row, you should see an improvement on each test page, sometimes you need to keep doing this clean/print until the nozzle becomes unclogged, if you don't see a difference in the 5-10 clean/test page then you need a new head
hope this helps
Thanks for your rating
monk3ybidzness
Level 3:
  • Epson Master 1,879 Answers
  • Posted on Jan 03, 2008
monk3ybidzness
Epson Master
Level 3:
Answers
1879
Questions
Helped
763903
Points
4784
Check if those lines matches the positions of the rollers inside the printer - you can see some of them by opening the cover
This evening I bought a new HP Photosmart C4780 printer. I am trying to print photos now and the photos are being printed with small vertical lines across the whole photo. How do I get rid of them?
> I bought a new printer
Take it back, and get one that does work correctly.
> VERTICAL lines ACROSS the whole photo
Hold the paper in "portrait" mode, not "landscape" mode.
Are the lines HORIZONTALLY-ACROSS the paper,
or VERTICALLY-DOWN the paper?
If those lines are WHITE and HORIZONTAL,
then some of the many ink-jets inside the print-head are *CLOGGED*.
Run a "print-head-cleaning-cycle" to try to unclog it.
Or, exercise the WARRANTY, and get it replaced.
1helpful
Epson R265 the disc print tray keeps jamming
did you align the track? check the tray for any cracks, when you try to print cd's make sure that the printer and cd are balanced in a horizontal or even manner
Horizontal lines (red) on first 1 - 2 pages of initial print-out
Do you refill ink tank? Print blank pages. Is there horizontal lines appear? It might be caused bay ink leakage. Check respiratory hole at ink tank and rubber seal at bottom of ink tank. Print blank pages until no horizontal lines and try to use new ink tank.
2helpful
Epson Stylus r220 prints with white lines... i installed a CIS and it worked fine for about 6 months, now i'm getting prints with white lines (or fine spots) i tried nozzle check, which comes out good......
Nozzle check must perfect for perfect output. There are tranversal lines at vertical straight lines that represent same point of head micro piezo. If tranversal lines no clog at all, but vertical straight lines not perfectly straight, the result not good (like horizontal white banding). Check it? Head aligment is for vertical banding. If your result is horizontal banding, you don't need to realign head. It's caused by some residual at the output of head sprayer. So, the spray of ink not straight to paper. Try to print with photo/best photo.
'empty' ink cartridges - green prints!
just fill up all the catridge bcoz in colour printer anyone of them is not fill up the printout not coming properly , after filling the catridge just check
Printing lines across the picture
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Overview&oid=90584
Q: How can I tell if the computer or the printer is causing a print quality problem? A: You can print a nozzle check pattern to determine whether the print quality problem is caused by the Epson Stylus Photo RX680 Series or some other source.
Above under FAQ
1helpful
2answers
Epson stylus photo R2400
I had this trouble, went through cleaning & realignment, then various print options. What i found was that dark colours had faint dark horizontal lines 5mm apart when printing on Photo in the epson driver. Changing it to Best Photo solved it.
5answers
If its doing it on all types of paper despite of any setting on printer driver, chances are you are having a hardware issue with the product.
pls try this site: support.epson.com try use passcode; lock
only applies for US printers
pls dnt 4get to rate soln hope the site will help thanks
Epson R265 Printer
2. TRASH and REINSTALL the drivers
3. Try a different application and file
4using a PHOTO PRINTER (Stylus PHOTO) try to set the QUALITY OPTION to BEST PHOTO or PHOTO RPM
5. Go to PRINTING PREFERENCES and hit ADVANCE
6. Choose the right PAPER TYPE, SIZE and SOURCE then disable HIGH SPEED
7. Once all those are set choose PHOTO RPM under the COLOR MANAGEMENT box and try printing
8. This will print a lot slower but will be using alot of ink and eliminate the lines
1helpful
Check status monitor see if cartridges are low or nearly empty , if new or full take out all cartridges and soak nozzles upright in cleaning solution overnight , or untill ink starts to bleed out:
Dab dry and re - fit , make up a A4 paper page with 6 colour bands about 1" high x 8" wide and print about 4 to 6 pages ,
check which colours are poor , if improvement is observed run
again a few times:
If one colour is poor take out that cartridge and soak again for a few hours , try again:
If no improvement replace with new cartridge or use a cleaning cartridge ( available on-line ) :
Using the head-cleaning utility shortens the life of the printer as the printer is set to lock-out after a pre-set use of the cleaning facility: and will have to be re-set instore:
[email protected]
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
