Computers & Internet Logo
Posted on Oct 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My kingston 8 gb data traveller suddenly became skymedi storage device.i cannot access it. can anybody help? thanks.
  • Anonymous Mar 17, 2014
    Try to clean your USB devices related to it, including USB root hub, then rescan from changes (device manager).
Anonymous
Level 2:
  • Expert 121 Answers
  • Posted on Oct 07, 2009
Anonymous
Expert
Level 2:
Answers
121
Questions
0
Helped
65401
Points
292
Try maybe it is bricked or damaged, try downloading Pheonix products which can help u repair any usb damaged storage media, worked on my 8gig usb and nokia n95, or u can try googling flashing utilities for you flash
I want driver for Kingstone Data Traveler G3 4 GB , Where i can get it , i use windows vista, please answer my question, i have been buy this device at price $80 , and it cannot read on my computer, i...
That device uses the standard USB storage driver in Windows. Try the device in a working Windows 7 machine. It will mount or you will see a message about formatting the drive. If it mounts your Vista is corrupted and needs fixing/reloading. If windows 7 wants to reformat the USB device, the USB device is likely corrupted and the data is lost. Or is could have been formatted for a Mac and cannot be read directly on Windows.
PS - $80 for a 4 gb USB drive is too much in the current market. You should be able to replace it for $10 or less.
I had purchased Kingston Data Traveller 1 gb from Delhi but it indicates full of data. Please let me know how to activitate it.
Yes, this is common......i stay in bangalore but I had visited Delhi once and I purchased Kingston Data Traveller at (Palika Bazaar) n the box had 8 GB on it and it was a sealed pack.....i connected the same to my PC and checked it said it is full.....I formatted it and then I came to know that it was not 8 GB but it was 512 MB......
Same Problem!!! the Error is |X| Cannot Copy the file: Cannot Fine the Specified file Make Sure you specify the correct path and the filename my USB devise having problem SKYMEDI USB drive 2GB and it cant...
Hi
try to format your kingston with
Following tool.(HP USB Disk Storage Format Tool )
from the site
http://www.softpedia.com/progDownload/HP-USB-Disk-Storage-Format-Tool-Download-123786.html
This tool allows you to format your pendrive either
in fat32 or NTFS
IN which NTFS is better
and also IT· Allows creation of a FAT32 volume larger than 32 GB.
An alternative is to format it in any linux
1helpful
Kingston data traveler shows as skymedi drive
You can follow the below commands
got to run
type cmd and press enter
then formatdrive name: and press enter
then it will ask for yes or no
press y
again do the above step once again your drive will be format
12helpful
4answers
Remove the write protection on 2GB USB Kingston Data Traveler 100
Found this on Kingston site, doesn't help much but may point you in the right direction.
Unfortunately this unit does not have any security or write protection feature. If you receive a write protection message with this drive, check for the following:
  1. Verify that you are allowed to write to removable storage devices. There may be a security setting in the OS that disables write access to removable storage devices.
  2. Make sure you have not enabled write protection on the drive by using a third party software.
  3. If none of the above apply, the drive may be defective.
16helpful
2answers
Kingston DT 101 II Usb Device become SKYMEDI USB drive
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
2answers
USB 2GB KINGSTON DATA TRAVELLER HANGS MY LAPTOP
USB KINGSTON CAN'T ACCESS TO MY LAPTOP.HOW CAN SOLVE MY PROBLEM.
5helpful
3answers
Skymedi USB drive is not recognised on my computer
i have usb kingston 4 GB data mini traveler, and my problem usb detect skymidi usb drive i dont know skymedi. i don't want if have format,because there are many data which is of important.
how is it's solution.
thanks 4 all
by blurz
3helpful
I can't format my 512MB kingston data traveler
Dude I just fixed mine running the SKYMEDI tool version SK6211BA_20080917 on my 8GB kingston datatraveler 100 is hard to get it but you will find it, you need to determine what version of the sw applies to your flash drive, check the SKYMEDI website www.skymedi.com.tw
Top Kingston Computers & Internet Experts
Jean Thiebaux
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
