I have a Sony Bravia model KDL-46s5100 that had the same problem. All HDMI ports stopped working. I don't know why this works but unplug the TV for about 30 sec, then plug it back in and hold down the power button on the tv for 10 seconds. Like I said I don't know why this works but it worked for me. Good luck.
I have a sony Bravia mod. KDL-52V5100 and had same problem with HDMI ports. They just stopped working. I called Sony support they had me try several things like resetting the tv, nothing worked. I just tried your trick of un-plugging and it works. THANK YOU!
I have a KDL-40SL 150 and my HDMI ports went out as well, I was worried about the high expense of getting the t.v. fixed and I came across this post. It worked for my set as well. Thanks so much for the useful information.
I had exactly the same problem with my Sony Bravia. I tried your solution and it worked perfectly. Thank you very much!!!
I have a KDL-52V5100 that i purchased in December 2009. The HDMI 2 Port stopped working for no reason. Had no signal. The others were working fine. Followed this trick and it worked. Amazing.
Wow. Spent 2 hrs on phone w sony w same hdmi ports stopped working issue w/ kdl-52v5100, next step was to call for service (tv out of warranty) when I then happened upon your fix of unplugging the tv..it worked! Thank you!
Another success story! Bless the internet and the kind folks who take the time to share their experiences.
After a few days of talk with comcast tech support, power cycling devices, trying dif HDMI inputs and replacing the cable box to no avail.... the unplug the tv trick works... why didn't I think of power cycling the TV...Doh!
Thank you so much for this post. Just wanted to post to say that this fix seems to work with other sony devices. I have a Sony vpl-bw7 projector that had the HDMI port quit. I gave this a shot just as a hail mary not thinking it would work. 40 seconds later my picture was back. Guess the software has a reset function built in. Again, thank you.
THANK YOU THANK YOU THANK YOU - I was so disappointed when my ports randomly stopped working right after my warranty expired - worked like a charm!!
I just had the same problem on my kdl-32xbr9. I called SONY and they told me to DL and install the latest software update. Now it works beautifully again. The only problem was I went out and bought a new 32:" SONY before I called them and now I have 2 good, working sets.
Go to www.sony.com/esupport and look for the software (firmware) update for your set and follow the instructions. I was told that 99.9 % of the time, this is why the HDMI ports stop talking to your peripherals. This software update might be the answer. Cheers.
Go to SONY website and find and download the software update for your set. This works. Cheers
This worked for me as well with my Sony TV
unbelievable. This post just saved me from buying a new hdmi cable and or then calling vans to figure out what's going on. First our ps3 would get the no signal, then the cable tv started doing it as well. Tried this unplug, power button trick and everything seems to work fine. Awesome, thank you so much.
Same problem w/ my Sony kdl-55hx800. Ports went out 1 by 1. At first thought it was an issue w/ new cable provider (recently switched, then first port went out within a week). Then every port I plugged cable box into went out. Wife googled problem and found this link. 30 sec unplug/ 10 sec power up did the trick.
OMG!!! we have almost exact model just a v not s (KDL-46V5100) and ALL Same problems!! have DIrect TV and xbox and TV is only 2 years old couldn't figure out what the problem is!! googled the problem came across this post and it so worked!!! THANK YOU!!!!
I have a Sony KDL-46V5100 TV and suddenly couldn't get my PS3 HDMI input on any port. Unplugging the TV and turning it on by holding the power button for 10 secs worked. Prior I tried everything I could find thinking it was the PS3 that was broken initially (unplugging the PS3, holding down the power on the PS3 for 6 secs to hear a total of 2 beeps while turning it on to reset the video settings, updating the PS3 firmware, bought new HDMI cables, tried incorporating an HDMI switch in the mix [ref:http://www.thebuzzmedia.com/ps3-hdmi-bla...]). I was about to try updating the TV's firmware when I stumbled on the solution. It's all working now and I was afraid to update the firmware since it's a non-reversible option though that might be the solution on your set up.
The unplug/power on for ten seconds trick worked like a champ for me!!! Thanks a lot!!!
Yup! Same here! Thanks for all the help everyone! My boyfriend wanted to switch out our TV for our 32" vizo. I wasn't going down with out a fight! :) Thanks for helping me keep the 60" in our living room!
Worked for my Sony Bravia 52". Both my Directv and PS3 would no longer work, but the other devices (Apple TV, Xbox) worked fine. I brought in another directv receiver that worked for a couple of hours, but then quit. I brought down a small TV with HDMI inputs and everything worked on it, so I knew it was the TV. I searched the internet and found this solution. WORKED GREAT! I hope this remedy lasts. Thanks for posting!
This worked for me as well. I don't have a power button on my Sony Bravia model, but I simply held down the power button on the remote. It turned on, I kept pressing, and it turned off. When I turned it back on, the problem was fixed. Thank you!
Worked for me too, unplugged TV for a minute then held down power button o side of tv for 10 sec.
Thanks guys! Same problem here. I thought I was going to have pay some bucks to a repairman to fix it. I followed your instructions and all 3 ports work again.
That k you soooo much!!!!! I was so scared xD
Thank you so much tpez your advise fixed my tv right before xmas!!!!!!! All of our hdmi ports on our sony tv were not working we tried what you said and it worked thank you again happy holidays!
This is why I love the internet. All of a sudden my PS4 wouldn't display on any of the HDMI ports on my Bravia. I checked to see if it worked on three other screens in my home that have HDMI support and it worked 3/3. Problem was the TV. I tried to connect my laptop to the Bravia; still no dice when the laptop also displayed output on the other 3/3 screens. I did a search on Google with the Bravia model number and seems the HDMI ports crapping out is a common problem. Performed the unplug + hold power for 10 seconds, PS4 all of a sudden displays. To whomever Anonymous person posted this, thanks so much for your insight. I'm not sure how you figured this out in order for the HDMI to start working again but your ingenuity saved me and others money and headache.
It worked !! Thank you.
I JUST CALLED SONY ABOUT MY TV AS WELL, I BOUGHT THE TV WEEK OF X-MAS 2009, LAST NIGHT MY HDMI INPUTS STOPPED WORKING AS WELL, THEY SAID I NEED TO SOFTWARE UPDATE, SO THEY ARE GOING TO SEND A FLASH DRIVE WITH SOFTWARE ON IT, PLUG IN AND FOLLOW DIRECTIONS, I HAVE DIRECT TV (NOT MUCH LONGER, GOING BACK TO DISH), A PS3, SONY BRAVIA THEATER SYSTEM, ANOTHER RECORDABLE DVD PLAYER, ALL I GET IS BLACK SCREEN WITH NO SIGNAL AS WELL, I WILL FIND OUT IF THE SOFTWARE WILL FIX IT IN 7-10 DAYS,
THANKS
This worked for me. My sony bravia 46 when it stopped taking signal from all my hdmi ports after i connected my xbox 360 kinect.
30secs unplug and 10 sec holidng of power button- and all is fine. Thanks.
Not only has my hdmi port stopped working, my avi and sd input stopped too. I'm going to try the unplug thing and pray for the best!
Unplugging the tv worked for me! Thanks for the help y'all! I got to keep the 60" bravia in the living room instead of switching it out for the 32" vizio that my boyfriend wanted to do. I'm sure he'll pay me back for "fixing" the tv. Thanks again!
I am having same problem and have tried the unplug thing but still not working can someone tell me do I hold down the power button on the t.v for ten sec or on the remote. I got excited when I finally found something that might work but yet again am let down.
Unplugging for 30 seconds and holding power down for 10 seconds worked!! I was ready to get rid of the TV!
TP eze back in 2010 shared a solution to solve HDMI ports stopped working. The suggestion worked. Have same Sony Bravia bought in 2010; in 2015 May, 2 of 3 ports stopped working-- unplug TV for 30 seconds, plug again, press and hold power button on TV for 10 secs, blink, blink, and done. All 3 hdmi ports work now. Thanks from Adele.
Thanks. it worked for me.. you save me $100 bucks
I have same tv and cant get hdmi ports to work tried reseting,turning off tv for 30 seconds trick. Use different cables ,still nothing.It was working for first 2 years with direct tv and ps3.
My PC is on tv mode it works but the screen doesn't turn on only when we connect the HDMI it says no signal
Help! I did this & my TV won't go back on!!
