2000 Harley Davidson FXD Dyna Super Glide Logo
Posted on Oct 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Rewireing 93 harley davidson FXLR to 96 Handle bar
Rewireing 93 stock harley davidson FXLR to 96 Handle bar controls, wireing color coding. The color coding on the OEM 93 FXLR, to rewire 96 + swiches to.
Anonymous
Level 3:
Brigadier General:
  • Master 4,565 Answers
  • Posted on Oct 08, 2009
Anonymous
Master
Level 3:
Brigadier General:
Answers
4565
Questions
0
Helped
2156230
Points
14358
On the handlebar switches, Harley hasn't changed the color code scheme very much over the years but you really need a good schematic to know exactly how they are wired up. If you can find either a Harley service manual for a 96 model or a Clymer's manual, it would be helpful. I have a schmatic for a 94 FXDWG that should be alright for your 93 FXR but you need a schmatic for a 96 model bike.
How do I Install a '96 Harley radio into a '99 Harley Davidson FLHTPI? And how do I get the wiring schematics for the '99 Harley Davidson FLHTPI?
96 mounting and wiring will be completely different. The handlebar controls on the 99 will not function on the 96 radio.
Search HD forums for the wiring diagram or buy then from harley
Replace handle bars
Mine had wiring inside the bars as well. Basically I removed the controls from the bars, and removed the 2 bolts holding the handle bars on. I removed the RIGHT side gas tank after draining it. I intended on cutting the wires to the connectors, pulling the wires out of the old handle bars, and pulling them back through the new bars. Note: Mark the black wires very carefully, since there were 5 black wires in the two connectors and they are all unique wires. The colored wires were easy, just match them back up. Several tricks I found on line. Use a string and a bolt to fish a pull line down through the new bars then pull the wire bundle through. This worked great on both left and right wire bundles. I then bolted the new handle bars in place and remounted the controls. I then replaced the shrink tubing up the bundles that hid the actual wires as they came out of the handle bars down to where I cut the connector wires, behind the right side tank. Next I stripped and tinned all the wires I cut (twist and get a little solder to stick on the wires) and stuck little pieces of shrink tubing up or down the wire so after I resoldered the wire I could shrink the insulation back over the splice. I picked up the shrink tubing and some extra wire a home depot. I had a soldering iron, and heat gun so away I went connecting the dots again. Litte tedious but hey. It saved me somewhere between $500 -$700 bucks which is what the harley shop quoted before I started. I tested each function, then reinstalled the gas tank and tightened up all the stuff. Below is the pin out in case you do loose a wire marker, like I did. Good Luck.
Replace handle bars
Top Harley Davidson Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
ZJ Limited
ZJ Limited
Are you a Harley Davidson Expert? Answer questions, earn points and help others
