I have 2-AXU4100 that I use for business but have lost the users guide,
I need to change the channels, however they are locked on ch. 1
I remember part of the instructions, such a:
1. hold the button on the side of the radio
2. turn unit on
3. select channel..........
However they are locked w/ the circle with the line thru it.
I need to know how to unlock, change channel & change PL
the radios should be on ch. 1 freq 463.525 w/PL. 136.5
On a Motorola AXU Series (including the 4100):
1. To unlock, press the “D” button for about a second or until the circle is gone. The circle with the line thru is the keyboard lock indicator;
2. To change channel, you need to press either the arrow left or right in Normal Mode;
3. To change PL (assigned to a channel), don’t think this can be done by the user
4. To change Ch. 1 from 464.500 MHz (PL-67.0) to 463.525 (PL-136.5), don’t think this can also be done by the user.
Even the built-in Programming Mode Parameters do not have this option to change assigned frequencies and PLs. An external programming software using a PC may or may not allow this.
These radios came pre-loaded with its channels assigned with specific frequencies/PLs. As used in a Motorola AXU411, they are:
Channel Frequency PL
1 464.500 67.0
2 464.500 77.0
3 464.500 88.5
4 464.500 179.9
5 464.500 None
6 464.550 67.0
7 464.550 82.5
8 464.550 94.8
9 464.550 179.9
10 464.550 None
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Hi again,
Glad to be of help and appreciate the rating.
Cheers.
And a Merry Christmas to you too.
Here's a link to a downloadable Motorola AXseries User's Manual. It's a 2 page pdf file.
73's from DU land.
1CCC
Thanks for your input. These rigs are licensen business band rigs and I have 10 freqs I can use with different PLs.
I finally got the problem figured out. The rigs freqs are 463.525, PL 136.5
What I can't figure out is why Motorola did not send the user manual on the internet like the lady I talked to said she would???
Anyhow you have all been very helpful and I thank each of you,
Have a Very Merry Christmas and a Happy New Year!
73 de W9LJH/AFA1LH
I have a motorola 2way radio a set of [two],And i would like to change the frequency of both them so that they can be on the same frequeny
I don't remember how to change the channels and keep it in that channel. I lost my user manual. Can you help.
