works best if you hard wire from LAN port of main router to LAN port on second router. 2nd router never has anything plugged into internet port. 2nd router has dhcp turned off. 2nd router has a ip inside the 1st routers ip range but not the same as anything else
Connect to three post terminal - black and red are interchangeable and belong on the right and left terminals. white goes to center, green goes to machine chasis not to any terminal post
Hay hun On a Caravan that Dont start it can be meny of things could be that your Distuter stoped workin on it most likely or it could be the Coil on it depends if it is tryin to start check on of them but if its not tryin at all Starter
no special adapter needed, just a simple usb port on system and ofcourse the drivers needed to install the device thru which you are trying to connect . just install the drivers thru a cd that was provided to you and it will work
