Question about KitchenAid K5SS Heavy Duty Commercial Stand Mixer
I've the 325 watts its 110V kitchen aid and I
I've the 325 watts its 110V kitchen aid and I want to use it with 230V what kind of transformer I need? How much KVA power?
  • KitchenAid Master
  • 5,569 Answers
You will need a 'step-down' transformer with a rating of at least 500 watts (~500 VA), a primary designed for 220 Volts and a secondary rated at 110-115 Volts. This type will have four terminals or leads and isolates the input from the output.
There is a non-isolating type called an 'autotransformer' which has one winding with a tap (total of three terminals) roughly in the middle. I use this type for certain devices but it is not as safe as the first-described type.
If you are living in a foreign country that uses the ~220 Volt standard, you can sometimes get one on 'semipermanent' loan from the local utility.
Posted on Oct 07, 2009
SOURCE:
Just bought kitchen aid prof 600 110v and i need a new transformer to 220v since my old one was busted using this appliance. What kind of transformer will i buy? Heavy duty ? Any spec? Thanks
You need one that can deliver not only the correct voltage but sufficient current to operate fully when under load. Check the current requirement on the sticker under the base, it will give operating voltage and watts. Purchase a transformer that matches the voltage and exceeds the watts by at least 30% so that the transformer is not operating at full capacity when under load. It will not matter if the transformer exceeds the watts by 100% or more but they do get bigger and heavier as the wattage goes up.
Dec 20, 2015 | Food Mixers
325watts of 110v transform to 220v is how much watts
New armature, new field assembly and new phase board will probably be a similar price to a step up transformer and a far better solution.
Jan 20, 2014 | KitchenAid KSM150PS Artisan Series Stand...
I stay in msia and recently i bought a PRO450 kitchen aid mixer from us. Msia's voltage is 250V while the mixer is 300 watt. I used adapter and the mixer does work but the engine is making noises. Is...
The voltage in US is 110-120 volts and the amperage is 60 amps. In your country the voltage is 250 volts which appears to be high as the general voltage in Asian countries 220 volts and the current is 50 amps You have to use a transformer/adopter which can reduce the voltage from 250 to 220 Or it is a universal adopter where this aspect is covered up. In that case you have to check the amperage. 300 watt is the power consumed and has nothing to do with low/high voltage.
Oct 07, 2011 | Food Mixers
What is the difference between the Kitchen Aid "KSM150PSMC" and the KSM150 ?? thanks
The KSM150 is the line of mixers with similar features. It is in the Artisan series, tilt head, 325 watts. All mixers in the KSM150 line have the same features.
The one that you asked about, the KSM150PSMC is done in metallic chrome.
Best regards, --W/D--
Feb 01, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Kitchenaid Heavy Duty 325 stand mixer. Making cookies and now the motor runs but it doesn't turn to mix. PLease help/.
kITCHEN AID ARTISAN 325 WATTS TILTING HEAD PIN CAME OF WHILE MIXING DOUGH. HOW IS THE EASIEST WAY TO INERT PIN BACK OR LINE UP THE HOLES TO INSERT PIN?.
FRANKAMOR
Feb 06, 2010 | KitchenAid KSM5PS Heavy Duty Stand Mixer
MODEL KP2670 KITCHEN AID MIXER,IT WON'T TURN,POWER SUPPLIED,BUT NO POWER BETWEEN SWITCH OUTPUT TO MOTOR.
fault in the armature is a possibility. danger of electrocution if you try to self repair. See service centre
Sep 14, 2009 | KitchenAid RRKP50 350 Watts Stand Mixer
Kitchen aid stand mixer bought in US, moving to Europe, 220v 50hz
I can not respond to the warranty issues. My kitchen aid mixer is past warranty as well. I live in a country that uses 220V and my kitchen aid mixer is 110V. I have been using my kitchen aid mixer for almost 4 years with no problems at all.
The converter boxes are supposed to blow the fuse on the converter before it reaches your appliance and cause any problems.
If you purchase a 220V kitchen aid (although it would cost more money) it would probably have more power because of the higher voltage.
Hope this helps!
Jul 29, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Will a Kitchenaid Pro 500 work in a foreign country with trans.?
Hi, This is not normally a difficult question. Normally the answer would be - Yes no problem. I have taken every kind of appliance overseas. But this particular model has an electronic speed control and finding out the exact details of the electronic clocking is a problem. My best guess is that it will work just fine but at a slightly slower speed like any other 60Hz appliance. Oh and by the way you're gonna need a pretty big transformer this thing pulls 325 watts so you should go to at least a 400 watt transformer for doughs and heavy batter. The thing you could do to find other folks experience is to go to the kitchenaid forum or military wifes forum online and ask if anybody has taken one of these overseas. Good Luck!
Feb 01, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Kitchen aid 110v 450watt, I want to convert to 220v
Hi guys,
The only available Kitchen Aid stand mixers on the European markets are the Kitchen Aid Classic and the Kitchen Aid Artisan.
The best way is to contact a Kitchen Aid service center / repair facility in your area.
Here is the European website of Kitchen Aid: http://www.kitchenaid.eu/eu_EU/ka/ka_europe.htm
If you bought a different Kitchen Aid Stand Mixer (like the Professional series) you probably won't find the required parts to convert it to a European model. The only way would be to use a voltage converter.
I hope this helps.
Sep 24, 2008 | Food Mixers
KitchenAid K5SS Heavy Duty Commercial Stand Mixer Logo
540 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
CJ C
CJ C
Steve Allison
Steve Allison
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
