It sounds like your pump in turning on/off with an air button on the top of the tub.
The pump not turning off could be either a bad air button, not sending enough air through the tub to operate the air switch in the motor or it could be a back air switch in the motor where the air hose attaches to it.
Take a large straw and blow into the air switch and see if you can operate the air switch on/off.
If it will turn on/off then you know you have a bad air button on the tub however, if you cannot get it to turn the pump on/off then you know you have a bad air switch in the motor.
Rod
US Parts Center888-521-6183
