1990 Dodge Ram Logo
Posted on Oct 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is speed sensor located - 1990 Dodge Ram
Anonymous
Level 3:
President:
  • Master 986 Answers
  • Posted on Oct 07, 2009
Anonymous
Master
Level 3:
President:
Answers
986
Questions
0
Helped
508133
Points
3165
The Vehicle Speed sensor is located on top of the differential housing. it is held in with one bolt and takes about 15 minutes to change. Part #56028 187AC. Always have the dealership check and verify for the latest updated part number. REMOVAL: Raise vehicle on hoist. Remove brake line mounting nut and remove the brake line from the sensor stud. Remove mounting stud from the sensor and shield Rear Speed Sensor Mounting . Remove sensor and shield from differential housing. INSTALLATION: Connect harness to sensor. Be sure seal is securely in place between sensor and wiring connector. Install O-ring on sensor (if removed) Insert sensor in differential housing. Install sensor shield. Install the sensor mounting stud and tighten to 24 N·m (18 ft. lbs.).
Install the brake line on the sensor stud and install the nut.
Lower vehicle. ,I hope this helps you?
2007 Ford Focus speed sensor locations.....all of them please?
https://www.google.com/search?q=2007+Ford+Focus+speed+sensor+locations
Where is the 2007 ford focus speed sensor located?
Vehicle History https://www.vehiclehistory.com > questions > where-is...
Located on the right side of the transmission near the output shaft. Like. (1). Leave your answer.
2 answers · Top answer: The 2007 Ford Focus speed sensor is found by watching: https://www.Youtube.com/watch?v=jxqItE9OI20 You will come into many issues with an engine. A gasket ...
2007 Ford Focus Sensor Locations
Rick's Free Auto Repair Advice https://ricksfreeautorepairadvice.com > 2007-ford-foc...
Oct 3, 2018 - Wheel Speed Sensor (Left Rear) (Wagon) At left rear wheel. Wheel Speed Sensor (Left Rear) (3 Door) At left rear wheel. Wheel Speed Sensor (Left ...
1helpful
2answers
Ok so I changed the speed sensor by the transfer case on my 2001 Jeep Cherokee sport (xj) and I'm having trouble finding the other speed sensor location any advice?
On a 2001 Jeep Cherokee Sport (XJ), there are typically two speed sensors: the vehicle speed sensor (VSS) and the rear axle speed sensor. The VSS is located on the transmission or transfer case, while the rear axle speed sensor is located on the rear differential housing. Here are some tips to locate the rear axle speed sensor: 1. Locate the rear differential housing: The rear differential is typically positioned towards the rear of the vehicle, underneath the rear cargo area. Look for the large metal housing connected to the rear axle. 2. Identify the speed sensor: The rear axle speed sensor is usually mounted on the differential housing itself. It will have a wiring harness connected to it. 3. Follow the wiring harness: Trace the wiring harness from the rear axle speed sensor. It will lead you to a connector that is plugged into the vehicle's wiring system. The connector may be located near the rear axle or along the frame. 4. Inspect the differential housing: Look closely at the differential housing for a small protrusion with a threaded hole. This is where the rear axle speed sensor is installed. It may have a retaining bolt securing it in place.
Speed sensors located on motor
Lorraine, speed sensors are not located on engines. there are transmission speed sensors and wheel speed sensors.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Speed sensors locations Google Search
Vehicle Speed Sensor Location
vehicle speed sensor VSS
wheel speed sensors Google Search
On a 1996 Cad. Deville, where is the tubine speed sensor located?
press the helpful button and follow me on fixya for more tips
Input speed sensor is located inside the transmission. The sensor is located next to the sprocket for the input shaft. The sensor is held in place with 2 6mm bolts, one for the sensor, one for the wiring harness.
Input Speed Sensor P0717 Replacement
P0717 ISS Speed Sensor Code Cadillac Deville Eldorado Seville Fleetwood...
Vehicle Speed Sensor Removal Installation
1helpful
2answers
Where is the transmission sensor located?
The transmission sensor or speed sensor is located in most vehicle located on the transmission case.These speed sensors are driven by a gear located on the output shaft. The speed sensor's driven gear can be either machined or fastened by a clip. The driven gear is made by plastic to make it softer than the drive gear. It's located on the end of the vehicle speed sensor.
2answers
Where is the input speed sensor located on the transmission?
Search Results
    How to Replace The Input and Output Speed Sensors On a ...
    ? 7:21
    www.youtube.com/watch?v=QCCQobQmp78
    Jul 23, 2013 - Uploaded by RatchetsAnd Wrenches Here is a how to on replacing the Input and Output speed sensors for a ... Is it the same location as this Year/Model? .... Are these the same sensors that my CEL code saying "Vehicle Speed Sensor Range/Performance"?
    images for input speed sensor location
2helpful
We are replacing a speed sensor. Where on the vehical is it located?
This depends on which speed sensor, there are abs speed sensors that are located on each wheel, then a trany speed sensor located on trany,and also trany input and out speed sensors located on trany.
1helpful
2answers
Where is the speed sensor located at on a 91 Honda Acoord?
1991 Honda Accord 2.2L FI 4cyl the Vehicle Speed Sensor is located mounted on transmission.
Hope help with this (remember rated this help).
1helpful
Location of speed sensor a for 99 dodge intrepid
The "Vehicle Speed Sensor" signal is generated by the transmisson output speed sensor. That is the one located at the rear of the case. It is externally mounted. That supplies "vehicle speed" info to the other On-Board Computers. The input turbine speed sensor is located just behind the bell housing area of the case. I believe the trans controller is the only module that needs that info. The Crank Position Sensor give engine RPM info and it is located on the bell housing near the engine block. I hope this helps.
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
