This is to further detail my boot problems with the f700. I have already reformated the machine, ran check disk and defraged (we're using vista) and it still has the problem. It will repeat the same problem on the boot up sequence regardless if you're trying to go into bios-safe mode-or regular boot up which is: the computer lights up and the screen goes blank. After 20 seconds or so you can see the power lite cut off and immediately back on and it repeats the same process. If I hold the power button down and do a hard stop on about the 3rd time the computer will successfully boot.
Hello there
Hints:
1) You got a driver or device problem,
2) use the drivers that cam with your f700 particulary these ones, 1) video card 2) sound card (sometimes if driver is bad, it can cause these problems)
3) RAM problems, to isolate the problem, if you have the expertise take ount one ram module at a time and turn on the computer. see if these helps!
SOURCE: Compaq c700 vista os frozen
that means your base system is working just fine but your other software is not.try to remember what type of software did u install b4 or on the first day u know your laptop frozen.....fyi, some system cannot work on vista..
Method 1: Use the Windows Recovery Environment (WinRE) to run System Restore
1. Insert the Windows Vista installation disc into the disc drive, and then start the computer.
2. Press a key when the message indicating "Press any key to boot from CD or DVD …". appears.
3. Select a language, a time and currency, and a keyboard or input method, and then click Next.
4. Click Repair your computer.
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next
6. At the System Recovery Options Dialog Box, click on System Restore.
7. Follow the System Restore Wizard instruction as usual and choose the appropriate restore point.
8. Click Finish to restore the system.
Method 2: Startup Repair from the Windows Recovery Environment (WinRE)
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next.
6. At the System Recovery Options Dialog Box, click on Repair your computer.
7. (Click the operating system that you want to repair), and then click Next.
8. In the System Recovery Options dialog box, click Startup Repair.
SOURCE: My compaq presario f700 has difficulty booting up.
Windows Start-up Errors
Step one, you need a Windows XP CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work. You can order a boot up floppy disk from here: http://support.microsoft.com/kb/310994 with this file, if you know how, you can use “ImageBurn” to burn the file into an ISO file which can be burned to a disk. Now make sure your computer boots to the cd rom first. If you know how to do this skip on down, if you don’t, while the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
Place your Windows disk in the computer and start it up. When you see the test at the top of the page “Press Any Key To Boot From CD” Just hit the space bar to activate. The next screen you will see will most likely be a Windows setup screen, when you see this press the “R” key to get to the recovery console. It will get there, it may take a little time, patience. Once it loads you will be given a choice of Windows installations, there should only be one, if there are more, always pick number one. It may ask for an administrators password, if you have not set this particular password, then just leave it blank and press enter. The next prompt you see is:
C:\Windows>
You need to type the following:
cd \
hit enter. Pay close attention to the spacing between the characters. There is a space between the character “d” and the “\”
You are now at the ROOT of the drive, this is where basic commands can be given and changed. You should now see the following:
C:\>
Now type the following:
CHKDSK /R
Hit the enter key.
The chkdsk /r command also includes the P command and will also look for lost recoverable information in bad sectors.
There are occasions depending on how corrupt the system is, that this process could take several hours, so be patient with it.
Now, after chkdsk has run type the following:
FIXBOOT
Hit the enter key.
It may prompt you with a warning, that’s ok, just continue. When fixboot has finished, type: EXIT hit enter and windows will reboot. When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key. If you were having some simple drive errors this should have fixed them.
SOURCE: My compaq prescario CQ45 is
There are a few reasons/causes of this.
The most common cause is the modem going faulty. Remove the modem and it may come back to life as it can't finish POST.
The Bios has an error, remove the Cmos battery and let the board discharge for 1/4 hour, re fit it and it may POST.
The uProcessor may need re seating and have a bad contact on a pin. Re seat the uProcessor and clean off old heatsink compound installing new.
Maybe as they are the most common I have come across, you may fall into one of them, I hope, otherwise it is a dead motherboard I'm sorry to suggest. Even if the RAM is faulty, it should attempt to POST.
