When powered on with the remote, the tv power button would light up, but no picture would appear on the screen. When this happened, the only way to turn the tv off was to unplug it (the remote couldn't turn it off, nor could you turn it off by pressing the power button on the tv itself). By unplugging the tv and then plugging it back in, we could get it to turn on and this worked for a few days, but now this isn't working either. We searched the web and found that this seems to be a very common problem with Polaroid. Some folks seem to have found a solution and were able to make repairs successfully themselves, but we need specifics about what part(s) to replace, how to do the replacement, and where the parts can be purchased. Thank you.
The power supply board was having problems before.That the board,where the power a/c cord plug into it Now might also the Tuner board are dead too.The tv Tuner board,that the board where the tv broscast signal cable plug into it.That the Tuner board.Tries Websites like shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement to see if solved the problem,not probally will have to buy the refurbish Tuner board for the replacement too.
i am having the same problem. My Phillips 37" 37PF9431D/37I LCD High Definition TV won;t turn on. When I press the power button i hear a click and the green light comes on for a couple of seconds and then the red light appears. I can;t figure it out. Did you find a solution?
it could be 2 caps on the power board, i had the same problem and for $3.39 at Radio Shack solved it.
There is a link on hre with pictures and instructions from stiv0, that works. Of course your on your own if you try it.
I had the same problem with mine, and figured out how to repair the control box. If you would like to have me perform a service on your set go to www.mikecampagna.com/Polaroid
