I need a manual to show how to put the wires from the icute casing into the motherboard to supply power i have 5 wires loose and i dont have a clue where to connect them the wires have labels on them which say, reset sw, power sw, hddled, plus pled and -pled, can you help
Hi, on the edge of your mother board closest to the front of the computer, you will find a double row of pins. Use a torch and if needed a magnifying glass and study these, you will find they are labeled the same as your cables from the case.
In some cases the plugs are set as a 3 space plug, if you find one of these that wont fit. just split it. If you plug the LED wire back to front, don't panic it won't hurt they just wont work. The power and reset are not pole sensetive.
Goodluck mistyman
