My sidekick 3 does not charge i have 2 press on the charger just so it can charge..is there another way for it to charge,without buying another battery/charger?
Re: my sidekick 3 does not charge i have 2 press on
No there is not it sounds like the connections inside have worn so the charger isnt chrarging. here is a link to buy one http://www.gyvergear.com/PayPal/sidekick/SK3TWN/index.html
The color is orange but that does not mean your sidekick 3 is charging correctly. The sidekick 3 has a charge problem becuase the connector port for teh charger breaks, you sill get the orangeligh, but the leads tthat go to the battery are broken so the battery does not charge. The cheapest thing to do is to get a cradle and do aworkaorund to charge the battery.
do you mean like the orange light is not light up when it were charging, correct? if so, then you need to get a new charger.
your charger is probably dead and no longer working.
if you want ,i have a brand new charger that i do not need(bec, i have few of them laid around and need to get rid of it) and will selling it for pretty cheap.
The sidekick 3 has an issue with thte charging port. If you have a friend with a sidekick 3 or sidekick ID, try one of their batteries. If your unit powers on, the charging port has gone bad.
the repair for a charginf port runs about 80-100 dollars. A cheaper work around is to get a charging cradle that has a spare battery charger slot. They run about 30 dollars on ebay and it will allow you to charge the bettery seperate from the phone.
let it charge for 2 hrs. NOw turn it on but beofre pressing button to turn it on, press and hold the l button then press the on button. Once yu see a sidekick icon that looks confused on yur screen, yu may let go and it will ask to reboot. And you do so. Hopefully this works for you.
Another option is to get a charging cradle that has a spare battery charging slot. They go for about 30 dollars shipped on ebay. This will allow you to charge your battery external from the phone or if you have an extra battery , have one charging at all times.
The Sidekick 3 is notorious for having the charging port go bad. New battery or charger doesn't help when this is the issue.
YOu can get it fixed for around 100 dollars or ou can get a charging cradle that has a spare battery charger. Since you have an extra battery it will work well for you. They are about 30 dollars from ebay.
All right. The Sidekick 3 has a known charging issue that crops up on some phones. If you are under warranty, call t-mobile and get it fixed. If not, the repair is going to run 100+ to fix the charging port.
A fast and simple solution is to by an external charger and an extra battery. They run about 30 bucks total on ebay.
