It sounds like the small silver piece that fell out of your BISSELL Powerforce Helix may be the motor brush. The motor brush is a small, spring-loaded carbon block that makes contact with the motor to conduct electricity. If the motor brush falls out or is not installed correctly, it can cause the motor to make a loud, high-pitched noise.
To fix the problem, you should locate the motor brush and try to reinstall it. The motor brush is typically located near the motor on one or both sides of the vacuum. You may need to consult the user manual or contact BISSELL customer service for specific instructions on how to access and install the motor brush.
If the motor brush is damaged or missing, you may need to purchase a replacement motor brush from BISSELL or a vacuum repair shop. Once you have replaced the motor brush, the high-pitched noise should go away and the vacuum should operate normally.
Sounds like something is clogged/blocking the intake hose. Pull off your bin & see if you can feel/see anything blocking that hose that everything goes thru.
To fix any noise issues that your Bissell vacuum gives, a proper maintenance will do the trick. Most of the time, cleaning the filters, checking for blockages and clearing the passageways will eliminate the noise. You may need to refer to your User's Manual for instructions on how to do proper maintenance.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
That noise usually means that the belt is worn or stretched and its slipping on the motor shaft. Replacing the belt is easy to do and you can get the belts for this model here:
High pitched noise usally happens when the suction pancake fan fins become loose on the shaft.Usallythere is two or more sandwiched on the motorshaft .. Matter of taking the tin split casing apart and check and tighten :^/
For the handle problem, detent lever part #2030052 and costs $4 to $5. A bearing in the motor is what is making it sound bad, part #2032211 and will cost around $60. You could try bissell.com or call them. They can at least let you know who has Bissell parts near you.
I chaanged the belt and that fixed the problem
when the vaccum is turned on the motor has a very high pitch sound
