Question about Samsung Digimax S630 Digital Camera
Samsung S630 date gets reset while changing the batteries
Samsung S630, the Date gets reset to a new date when I change the camera batteries. Is there any other battery for date which I can change to fix this problem or there is some other solution.
    Scholar:
  • 39 Answers
It is really NORMAL that the date will be reset to the Manufacturer's date whenever you are changing batteries.
For you not to keep on changing the date and time of your camera, use Rechargeable batteries for a longer battery life span but make sure that you will be setting the battery type of your camera for the Rechargeable ones.
To set the correct battery type.
- Press on MENU button
- Press on the right button until you see SETUP 2
- Scroll down until you see BATTERY TYPE
- Select ALKALINE if you're using NON-RECHARGEABLE
- Select Ni-MH if you're using RECHARGEABLE
- Press on OK/MENU button for changes to be saved
Turn off camera after the settings
have been changed to refresh the camera.
Posted on Jan 12, 2008
SOURCE:
How do change the date
System setting or search manu
If you need further help, I’m available over the phone at https://www.6ya.com/expert/richard_b59056c0c62ecb00
Jul 25, 2014 | Samsung Digimax S630 Digital Camera
Dear Expert, I have a problem with my Samsung L100 camera with the time and date. Somehow when I have uploaded the pictures onto my computer it gives the date of the future for example: May 21st 2013....
The date of your pictures is from the date you took it, So, it must be that last year, May 2010, when took those pictures, your camera's date was not set to 2010. You must also know that when a camera's battery is totally drained and stocked for a long time, the date will be reset. So next time make sure that your date is always right on your camera. =)
But here is a good news. You can just change the dates now after downloading it to your computer. Go to the picture you want to change the date, right click on it and choose properties. Click on details, then "date taken" and change it to any date you want.
I hope this helped you.
May 21, 2011 | Samsung L100 Digital Camera
How do I delete pictures?? How do I change the date on my camera??
Use the arrow keys to highlight an image and press the delete button(the one that has a trash can image on it). See page 66 of the manual below
Right-click here and click save target as to save the manual
Instructions for changing date/time are in page 33
Oct 04, 2010 | Samsung S630 Digital Camera
Date and time setting
The date/time is in Setup 1 (the wrench icon in the middle). Scroll down to Date & Time, then click the right side of the wheel button to set the date and time.
I hope this helps! If so, please rate the solution.
Regards,
Char1ieJ
Dec 16, 2008 | Samsung S630 Digital Camera
Is it a power problem or something else
Perhaps you are using low quality batteries-
Does the packaging suggest that they be used for digital cameras? Have you checked their expiry date?
Jul 06, 2008 | Samsung Digimax S630 Digital Camera
My samsung wont turn on
It's not the camera. Are your batteries suggested for digital camera use? Have you checked the expiry date? this camera is quite the battery ****- even if your batteries show up as fully charged, a lot of brand's don't have enough power to support this camera, so MAKE sure you buy good batteries.
Jun 30, 2008 | Samsung Digimax S630 Digital Camera
Low battery
Your cam has a not so rare battery drain defect, mine had the same problem.
call Samsung and send yours in, they will either fix it or give you a new one.
May 26, 2008 | Samsung Digimax S630 Digital Camera
Change date on lcd monitor
hi, i only just recieved this camera today, but after my confusion with working the date i figured out how to change it.  first; press the menu ok button in auto mode. a sort of menu appears that will say recording etc. then flick across to the little wrench1 sign and go down until you get to date and time then press ok and across again to get to it. to change it go up and down until you get to the correct date. same with the time. hope this helps, i have an s630 but im sure they are the same, try it anyway.
Dec 19, 2007 | Samsung Digimax S730 Digital Camera
Samsung Digimax S630 Digital Camera Logo
635 people viewed this question
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
