Bosch Tassimo Coffee Machine leaking water underneath the machine which in turn tripped the electric supply - however no warning lights on the front of the machine
I'm having the same problem with my machine. I rang the Tassimo careline and they told me to descale the machine but, so far, this has only made matters worse. I'm now going to take it back to where I got it from because it's still within its warranty.
Further to my previous post. I've just read that it may be a problem with the piercing unit and that you should check the rubber seal for damage. If that's the case you can buy a new one from www.bosch-eshop.com.
I have a simular problem, piercing unit seal seems OK, but can clearly see water inside the machine when I lift the sides. Probably ruptures hose (also from parts shop), BUT how do you open up the thing in the first place???? Does anybody know this for a TAS4011GB, pls
All the lights are flashing on my Bosch Tassimo as soon as I turn it on
there is always water under the machine. maybe something is leaking. how is the coffee maker to open?
