I've had this same problem, I've tried pushing the DND button it doesn't help, we've unplugged it from all sources for over 30 hrs still not helped? Any solutions or advice would be helpful. Thanks!I've had this same problem, I've tried pushing the DND button it doesn't help, we've unplugged it from all sources for over 30 hrs still not helped? Any solutions or advice would be helpful. Thanks!
You can't post conmments that contain an email address.
If you had a power failure the memory may have been affected.
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
You may need to register the handset to the base by
following the instructions in the user's manual
For GE 6.0:There is a button on the base lower right corner (NOT the phone), you need to press it once again to turn off Do Not Disturb
For GE 5.8 GHz:1. Pick up the phone handset and dial *98. 2. Press 2 to disable Do Not Disturb. 3. Once you hear the confirmation that Do Not Disturb has been disabled, you may hang up the phone handset. Hope this helps!
The day and time need to be reset. The phone has day, hour, and minute buttons on the back. Hold the button down to change to the correct setting and it should solve your problem. You can also go to www.ge.com/phones and pull up a copy of the instruction manual.
Which button? My daughter was playing with the phone so I don't know which one she pressed.
Thanks!
how do I remove the "DO NOT DISBURB"
