my tv is a SONY kv - 35xbr48 it turned off by itself and will not turn back on either by remote or power button. the fuse is good. seems like no power can you help me?my tv is a SONY kv - 35xbr48 it turned off by itself and will not turn back on either by remote or power button. the fuse is good. seems like no power can you help me?
AnonymousFeb 14, 2008
I have a 20" phillips non flat screen tv that will not turn back on, it shut off while my wife was watching it .I have a 20" phillips non flat screen tv that will not turn back on, it shut off while my wife was watching it .
AnonymousMar 03, 2008
polaroid 32"lcd tv will not turn onpolaroid 32"lcd tv will not turn on
Hi I have a Sony KV-26V66, that won't turn on. The standby/timer LED blinks 2 short and 1 long.Hi I have a Sony KV-26V66, that won't turn on. The standby/timer LED blinks 2 short and 1 long.
I have a panasonic tv that will not turn on. It makes no noise at all when the power switch is switched. We checked all the obvious...(power to tv, etc)I have a panasonic tv that will not turn on. It makes no noise at all when the power switch is switched. We checked all the obvious...(power to tv, etc)
I have a philips 27". model # 27PT543S37A. When I turn the power on, i Hear a clicking in the back repeatedly then it turns off. When I do get a picture about 10 to 15 minutes later of repeatedly turning the power on and off, it will stay on for a couple hours then the screen goes black.I have a philips 27". model # 27PT543S37A. When I turn the power on, i Hear a clicking in the back repeatedly then it turns off. When I do get a picture about 10 to 15 minutes later of repeatedly turning the power on and off, it will stay on for a couple hours then the screen goes black.
I HAVE A PHILLIPS 27" NON FLAT TV THAT WILL NOT TURN ON....MODEL #27P6441/37I HAVE A PHILLIPS 27" NON FLAT TV THAT WILL NOT TURN ON....MODEL #27P6441/37
I WATCHED TV THE NIGHT BEFORE THE NEXT MORNING I WENT TO TURN IT ON. IT WOULD NOT COME ON. ALL I HEAR IS A CLICKING IN SIDE THE TV. THERE IS A INDICATER LIGHT THAT FLASHES IT LOOKS LIKE IT WANTS TO COME ON EVEN AFTER I PUSHED THE ON BUTTON IT STILL FLASHES A FEW TIMES IT IS A JVC 52 IN REAR PROJECTION TV ANY HELP AT ALL THANKSI WATCHED TV THE NIGHT BEFORE THE NEXT MORNING I WENT TO TURN IT ON. IT WOULD NOT COME ON. ALL I HEAR IS A CLICKING IN SIDE THE TV. THERE IS A INDICATER LIGHT THAT FLASHES IT LOOKS LIKE IT WANTS TO COME ON EVEN AFTER I PUSHED THE ON BUTTON IT STILL FLASHES A FEW TIMES IT IS A JVC 52 IN REAR PROJECTION TV ANY HELP AT ALL THANKS
I have a Protron. It worked today. I turned it off. A few hours it won't come back on. This is the first time this has happened. I have a Protron. It worked today. I turned it off. A few hours it won't come back on. This is the first time this has happened.
Citizen C20401 CRT 20" TV will not turn on from standby. Red light is on... Goes off when on/of is pressedCitizen C20401 CRT 20" TV will not turn on from standby. Red light is on... Goes off when on/of is pressed
Citizen C20401, my son broke the remote and then put on the sleep timer and now we can't do anything with itCitizen C20401, my son broke the remote and then put on the sleep timer and now we can't do anything with it
You can't post conmments that contain an email address.
It sounds like your tube Shadow Mask may have got magnetised and need to be degaussed.
Turn off your TV at the mains and unplug it for at least two to three hours. Longer the better. After that time power up your TV it should degauss the tube at power up.
Worth a try before you give up on it. Or else get your picture tube replaced. It may be more economical than purchasing a new television. Also try to have the picture tube of an old color T.V as modern picture tubes lacks quality when compared to older ones. But check those tubes thoroughly before buying it.
hello, the convergence ic's have gone bad in your tv . and sometimes they fail because of a 50 mfd @ 50v capacitor by each ic goes bad. if you have the skill at soldiering and desoldiering you may try repairing it yourself otherwise leave it to a qualified repairman. thanks .....techman...580-243-8025
You need to put the TV on Video Mode. Press the TV/Video button on your remote or the Input button. Toggle between the selections and it should detect the PS2.
Yes, Mitsubishi did make a DLP that did not use a color wheel, but I am not sure if they still make it. It would be in the Diamond series and it uses 3 image units. I believe this was a professional set and was very expensive. You may have to ask around at you local electronics store to see if Mits still make this set.
Yes this is the signal for a bad lamp. Other things can cause this. 1. Look at the new lamp. make sure it still looks good. not broken with little glass pieaces in it. 2. When you turn on the tv, put your ear to the lower back part of the tv near the middle. Listen for the start up of the color wheel (a low high pitch sound only at the start up of the motor). If this is good you will here a ticking sound only if the lamp dose not light.
Now with all this info. If the lamp lights (as seen from the back of the set) and goes out after a few seconds and you did not here the color wheel spin up, the color wheel is bad.
If you here the color wheel spin up and no ticking sound, the Ballast is bad.
The ballast part no. 939P978010
The color wheel is not avialable from Mits. You will have to replaced the light engine. It cost to much. Just buy a new tv.
I too have the same problem. We've had the ilo27 for almost 2 years and
it suddenly decided to not turn on anymore. Red light-itus.
I did find a little trick if you are not so mechanical like me and don't want to risk opening the back. I know this isn't a cure, but you CAN get around this by simply pulling the plug from the wall and plugging it back in. It comes on with remote or manually every time!!! A little inconvenient, but a way around it temporarily!
