Issue
The error message
'An error occurred while communicating with scanning device' appears on the computer running Windows XP.This error occurs while using the HP scanning software.
If the error message appears on the computer while scanning from a
networked product,
click here to troubleshoot scanner communication errors for the networked product (c00897542) (in English). This document does not cover the communication error message on networked products.
Solution
Beforeproceeding with the solutions in this document, use the product to makea copy in order to make sure that the hardware is functioning correctly. Ifthe copy function does not work, this document will not help resolvethe issue. Search the HP Web site for a document covering the errormessage that appears on the computer while copying. Ifthe copy function works, try each of the following solutions in theorder presented. After completing the steps for each solution, test theproduct. If the product still does not work, then proceed to the nextsolution.
NOTE:
Someof the following solutions require that the computer be restarted.Consider printing this page or creating a bookmark to it, so that itcan be referenced after restarting the computer.
Solution one: Restart the All-in-One and the computer
Follow these steps to restart the product and the computer.
NOTE:
Make sure that the product is connected directly to an electrical outlet and not through a surge protector or power strip.
- Turn the power to the computer off.
Press the power button () to turn off the product.
- Wait 10 seconds.
- Restart the computer.
Press the power button () to turn the product back on.
- When the computer restarts, try the scan again.
If these steps resolved the issue, you do not need to continue troubleshooting.
If the issue persists, continue to the next solution.
