Question about Konica Minolta bizhub 350 All-In-One Laser Printer
How do I install Konica Minolta Bizhub C350 copier using a router and 1 computer with Vista 32-bit?
  • Konica Minolta Expert
  • 158 Answers
To setup LPR Printing, perform the following:
For Windows 2000/XP/Server 2003:
1. For Windows 2000, click the [Start] button, point to Settings, and then click Printers.
2. For Windows XP/Server 2003, click the [Start] button, and then click Printers and Faxes.
3. Right-click the icon of the installed printer, and then click Properties.
4. On the Ports tab, click the [Add Port] button.
5. In the Available Printer Ports list, select Standard TCP/IP Port, and then click the [New Port] button.
6. When the Add Standard TCP/IP Printer Port Wizard starts up, click the [Next] button.
7. In the Name of printer or IP address box, enter the IP address for this machine, and then click the [Next] button.
8. Select Custom, and then click the [Settings] button.
9. Select LPR, enter Print in the Queue Name box, and then click the [OK] button.
10. Click the [Next] button, and then click the [Finish] button to apply the setting.
Posted on Oct 24, 2009
SOURCE:
Steps to install c350 and the drivers
Your Konica Minolta Bizhub C350 Digital Copier, Printer and Scanner should come with a CD/DVD which includes the drivers for different operating systems AND a PDF fie with user's manual. Even is possible that yo may fine several PDF files, in different languages.
So open your PDF file and find the section where it describes with enough detail the steps you should follow . Probably there are different procedures depending the version of Windows, MAC or Linux you are using.
http://kseroimpuls.pl/broszury/en-bizhub-c350.pdf
If you don't hat user's manual, get it from here:
Konica Minolta C350 User Manual
Jul 08, 2015 | Konica Minolta Bizhub C350 Digital Copier,...
Konica Minolta c350 printer driver install
You need a Ethernet cross over cable. plug that into computer the other in to copier
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 06, 2014 | Minolta Office Equipment & Supplies
Konica minolta bizhub c350 error codes c-0510
eror code c-0098 meaning ??????????????pls tell me the solution
Jul 31, 2012 | Konica Minolta Bizhub C350 Digital Copier,...
Konica minolta bizhub c350 installer for mac
You have to have a fiery unit (external controler) to use the C350 With a Mac because the c350 dosnt come with appletalk in the software. IC-401 Is the model number of the controller you will need to connect the c350 to any kind of mac for printing / scanning.
Mar 14, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Printer not receiving information from computer
I guess you mean the c350 is not printing while Windows said the job has been sent? If so, it may have changed IP Address from the time you first install the Printer on Windows. Check the Ports setting of the c350 printer! e.g. d53b002.jpg
Network Pritners should have Static IP address or at least a reserved DHCP IP Address. Logon to your Router, check the MAC Address of the c350 and reserve/assign it a IP Address near the end of the DHCP range. Save the Router configuration and power cycle the c350. Confirm IP Address changed to the reserved IP.
Then you have to change all the PC's Printer Configuration of the c350's Port to update the reserved/assigned IP. Or remove the c350 from Printers and Faxes, then run the printer setup software again.
May 23, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
I can't print from IMac to konica-minolta buzhub C350
Go to konicaminolta web site and download a mac driver. and install it to Imac. Make sure to download OS10.4 or higher.
May 11, 2009 | Minolta C350 Printer
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
589 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
