Uniden 5.8GHz Dual Cordless Phone Logo
Posted on Oct 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cannot acess option to record outgoing message need to get to option 8 to record message
Anonymous
Level 2:
  • Expert 52 Answers
  • Posted on Oct 05, 2009
Anonymous
Expert
Level 2:
Answers
52
Questions
0
Helped
9291
Points
157
All phone is no recoed outgoing ok than you can incoming call to record tha message
1helpful
I have the uniden dect 6.0 3 handset. I lost my manuel and do not know how to record my answer message
Which specific Uniden DECT 6.0 phone do you have? There are a number of them. Uniden has the manuals available here: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl . Phones are listed in alphabetical and numerical order.
If the answering system is off, turn it on before proceeding to the following steps.
If you are at home, there are usually two methods to access the answering system. Some Uniden phones let you set the outgoing message from the base or the handset. Others will only let you set the message from the handset. (Calling in remotely is more complicated.)
To access the answering system menu from a handset, on some models, push the Mute/Messages button. Then let your current message play or press 5 to stop the recorded announcement. Then either use the up/down arrows to select Record New Greeting (or the number that matches the sub-menu item). It's number 8 on the DECT1480. Then wait for the prompt (tone or "Record Greeting") and then speak into the handset clearly. Press 8 to stop recording and press End to save the message. Press 6 to select the outgoing greeting if a default greeting is available.
On other Uniden DECT phones, press Menu and go to Ans Setup. Then choose the line for the greeting (if it's a multi-line phone) and then select Record Greeting. Press Start, wait for the prompt and then press Stop when done. Press Stop again to save the message. If there is an optional pre-recorded greeting, use the Greeting Option submenu to select the greeting to play. (This applies to the DECT4086.)
From the base, you'll do something similar. However, you should stay about 9" from the microphone while recording. Messages can be between 30 seconds and 3 minutes 30 seconds for most systems.
I hope this helps.
(recording a new greeting during a remote call can be done but consult the manual for details.)
1helpful
How do I change my outgoing phone message?
Welcome to Fixya
Press envelope/mute icon. The system announces the number of new and old messages, then starts to play the
messages unless it has no messages.
Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the
system is in the command waiting mode.
Press 8 to start the recording. The system announces, "Record greeting." Begin recording after the
announcement.
When you finish recording, press 8 again or press 5. You will hear a confirmation tone, and your recorded
greeting plays back for you.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
I have recorded an outgoing message. However, at the end of the new outgoing message an old obsolete outgoing message starts to play. How do I get rid of the old outgoing message?
You will need to remove the old message. There SHOULD be prompts. IF NOT try going to a very quiet room and hit record but do not say or make noise and this will record silence over the old and new message. Then attempt to retry.
ALSO - look for a 'reset' button and remove all batteries if you have power outage back up batteries.
Unplug the phone - and try again.
Here are the instructions from the manual:
To Change Your Personal Greeting:
1. Press the Check Voicemail key or press the Feature button, then 981
2. Enter your password
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
Best of it
Gary @ Fix Ya
How do i get messages from remote location
To use your system from a remote telephone, you must first enter a 3-digit remote operation security code. The security code label is located on the bottom of the system.
1. Dial your phone number.
2. When your outgoing message is playing, enter your remote operation security code. Bd appears on the display to indicate the system is in remote mode.
If there are no new messages, you hear three beeps.
These are the remote codes available to you:
2 # Play all messages.
2 5 Play new messages.
3 # Delete all old messages.
7 # Record new outgoing message.
7 # Stop recording outgoing message.
8 # Record memo.
8 # Stop recording memo.
9 # Turn system off/on.
0 # Monitor the room..
2helpful
How to record Outgoing Message on Answer machine of BINATONE FUSION 2210 DECT phone? Thanks
hi,
if you want to record outgoing message on Answer of BINATONE FUSION 2210 DECT phone, his the step you will follow.
to turn A/M on press R then 5.
to turn A/M off press R then 6.
if you want to record Outgoing Message, press R then 1.
After beep record your message.
Press 0 when you have finished your message, then C to return to standby mode.
To listen to incoming messages, press R then 8.
New messages are then played back.
Press 4 to delete message.
thanks for using fixya
1helpful
How do I record new outgoing voicemail message
depends on your provider, if you call your own phone number (voicemail) it should give you options to change a few things, if not contact ur provider
7helpful
2answers
I need to change the outgoing message on the main line. I can change the personal greeting, but I cannot find instructions regarding changing the main line's outgoing message
For Partner Voice Messaging....
Dial into voicemail. WHen prompted for the mailbox number
Enter 0 #
Pswd the default is 1234 followed by #
Option 3 is the record Automated Attendant menu prompt
the rest is self explanatory.
2answers
I wish to create my own message on the answer-phone.
The easiest way to gain access into an answering machine is to use it's preset access code. This is the access code set at default by the vendor on the given device. The best thing about this is that most users don't bother to change the access code to their device, if they even know that they have such a feature. Even worse yet, some of the manuals given for the device by it's vendor even tells the user that changing the access code is optional, not necessary. So of course since most people only do what they feel is necessary, these access codes are many times if not usually set at default. So what I'm going to do for you now is list the different popular vendors out there, and include their preset access codes, how to use them, and controls to use after gaining access. Keep in mind that if there is no model number beside the vendor, then that means that the information given works on most of their models. Likewise of course if there is a model identification beside the vendor name (placed in parenthesis) then that of course means that the information provided is model dependant. So let's begin, shall we?
1) AT&T - preset access code is 10 - when the answering machine picks up punch in the access code
7 - play messages
6 - play new messages
# - stop/pause
2 - repeat message
5 - skip message
4* - record announcement (push # to end recording)
41 - play announcement
* - record memo
33 - delete all messages
3 - delete selected
0 - turn system on
88 - turn system off
99 - change remote code
2) BellSouth - preset access code is 555, Mailbox 1: 555, 2: 666, 3: 777, 4: 888 - when the machine picks up hit * and then punch in the access code
0 - help (use this to get the commands available)
3) Freestyle - preset access code is 000 - when the machine picks up push in the D button and then punch in the access code
2 - play all messages
3 - play new messages
4 - skip back during messages
5 - delete during messages
6 - skip forward during messages
8 - play outgoing message
9 - record new outgoing message
0 - set answering machine on/off
1 - hear main menu
4) Vtech (VT650) - preset access code is 0000 - enter access code during announcement
#4 - repeat message
#5 - pause message
#6 - skip to next message
#7 - delete message
#8 - skip backwards
#9 - stop/exit any function
*8 - room monitor
5) Vtech (VT2650/VT2468) - preset access code is 50 - enter access code during announcement
#4 - repeat message
#6 - skips message
#5 - stops
#9 - delete message
#7 - review announcement (after beep press 7 to record an announcement and use #5 to stop)
6) Vtech (HK5886) - preset access code is 48 - enter access code during announcement
#1,2,3 - play new or old messages
#4 - repeat message
#6 - skip message
#5 - stop
#9 - delete message
7) Olympia (OL2410) - preset access code is 0000 - enter access code during accouncement
1,2,3 - select and play messages
4 - repeat message
44 - ignore message
6 - play next message
7 - delete current message
8 - record memo
9 - record announce (5 to stop)
0 - toggle answer on/off
* - play help menu
8) Doro - preset access code is 321 - enter access code right after outgoing message has played (or during)
1 - repeat/skip to previous message
2 - play/pause message
3 - skip to next message
4 - play current outgoing message
5 - record new outgoing message
6 - stop
7 - erase current message
8 - switch off answering machine
9 - switch on answering machine/select outgoing message
0 - (after playback) erases all messages
# - end playback
## - end call
9) Virgin Pulse cordless phone - preset access code is 123 - enter access code during outgoing message
1 - review current message
2 - skip to next message
3 - erase the current message
4 - play all or new messages
7 - repeat voice menu
0 - turn on/off TAD
10) Panasonic - preset access code is 11 or 1111 - enter access code during outgoing message
4 - new message playback
5 - all message playback
1 - repeat
2 - skip
9 - stop
7 - record new announcement (use 9 to end recording)
There are also a few random vendors that don't automatically preset an access code on the machine, forcing it's user to set one up him/herself. This is a small step forward as far as security is concerned, but every vendor I saw that did this still used a mere 2-digit access code. To test and see if your target has this type of setup press # when the machine start, and then press 0. If the machine returns to the annoucement then you know this is the kind of machine it is. Of course, in reality, this isn't all that bad of a scheme since you have 100 different combinations available for the access code. However, most users simply set these access codes as 11, 22, 69, etc. So yeah, just try it out. If it disconnects you after so many tries, call back from another payphone (which you should be using in this case).
Thanks for contacting Fixya
Jun 17, 2009 • Cell Phones
Nseed to reset message on answering machine
There are two models - The TRU8885 and the TRU8885-2 -
For the TRU8885 the manual PDF form >>>Click Here<<<
The solution is on page 24 + 57 It starts on Pg 24 as...
Record Greeting allows you to record a personal outgoing message (greeting) which
the answering system automatically plays when you receive a call.
1) Enter the Answring Setup menu, and then the
Record Greeting sub-menu (see "Entering the
Menu" on page 16). To record greeting press
[STA RT] appears.
2) Press the START soft key. You will hear “Record Greeting.“ The message counter
displays 30 and then begins to count down.
3) Position yourself near the base microphone and record your greeting.
4) When you are finished recording, press the STOP soft key. Your greeting will
playback for confirmation.
Selecting Your Greeting (Base only)
Select Greeting allows you to choose between the two outgoing messages, a prerecorded
message or your own greeting.
1) Enter the Answ. Setup menu, and then the
Select Greeting submenu (see "Entering the
Menu” on page 16). P lay back greetin g
appears, and the current outgoing message is
played. LCD is an example if you recorded your greeting.
2) Once you have recorded a personal greeting, press the CHANGE soft key to
choose the greeting. The selected outgoing message is played. Each time you
press the CHANGE soft key, the phone switches the outgoing message between
the prerecorded and the personal outgoing message.
There is more on the PDF - Just ask if you need more
For the TRU8885-2 is essentially the same. The manual PDF form >>>Click Here<<<
If we need to dig further, just ask! :) We are just a mouse click away!
Thanks
Len
I can't remember how to record my outgoing message ?
here you go...
Recording your greeting
message
You can record your own greeting
message (max. 2 minutes and 30
seconds). If you do not record a
greeting message, a prerecorded
greeting message is used.
1 {MENU}
2 {V}/{^}: “Answering devicei
{OK}
3 {V}/{^}: “Record greetingi
{OK}
4 After the handset beeps, speak
clearly about 20 cm (8 inches) away
from the microphone.
5 To stop recording, press {OK}.
6 {OFF}
If this helps you solve it, plz rate this fixya. Thank you kindly.
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
