Hi, my 32gb kingston pendrive is not working properly, all the data stored are corrupted. am not able to delete, copy any thing or format the drive.. please solve my problem
try formating your pen drive using formatting freeware HPformatting freeware down load it from below site run it and format your Pendrive then try to store it will work
When i copy any data to my 32 Gb Kingston pen drive whether any audio
or video file or any software, the data get corrupted or may be
deleted. some trimes it happen that some of the AV files are working.
Why this happened that the data are deleted. I have lost many of my
files due to this.It cannot be fomatted also. Please sort my this
problem. Thanx
The "other PC" needs to have the same application installed that created the files. It sounds likely that is the problem for the other PC. If the files are failing to open using the PC that originally copied the files, then try formatting the USB drive (formatting deletes all data). Before you copy the file again, make sure the same file opens from your computer prior to copying it. Now copy the file to it the USB drive again.
this problem may be due to a strong virus
just go through Dos promt
by writing cmd in run place at start menu
and then cd..
till u not get c:\ prompt
then write pendrive location like g: and press enter button
then u get g:\ then write format and press enter
hope by this process u will format ur pendrive
I have worked through this problem. It is a new virus attack. you should get your antivirus updated and then get your drive cleaned. It surely will help you solving your problem.
