I need instructions on how to program my Sanyo TV and i need the codes for that tv
I don't have a code book for you, but I can tell you how to program the RCR660 using the automatic programming feature.
Programming RCA model RCR660 (no code search button)
While following these instructions, keep the following in mind:
device = the component you wish to control with your remote (TV, DVD, VCR, etc.)
DEVICE = the button labeled for the component you wish to program
1. Turn on the device you wish to program.
2. Turn off all other devices in the general vicinity.
2. Press and hold DEVICE
3. While holding DEVICE down, press ON/OFF and hold them both down until the LED turns on for that device.
4. Release both buttons.
5. Point the remote at the device, press and release PLAY and wait 5 seconds or until the LED stops flashing.
6. If the device does not turn off, then continue to press PLAY and wait the required interval (for a maximum of 20 times) until the device turns off.
7. When the device turns off, press REVERSE, wait two seconds and continue doing this until the device turns back on.
8. To finish programming, press and hold STOP until the LED turns off.
I need the code for a LG lcdtv
Works great
SOURCE: need code list for a sanyo tv and progam instructions
Here is a useful link that i found for you.
http://www.ehow.com/how_9191_program-rca-universal.html
I hope i have been helpful
Regards
i cant find out how 2 use my input on ma tv and i just set the code
have the same problem with the input....??
need rca universal code for sanyo ty
