HAD TV FOR JUST UNDER A YEAR ITS BEEN FOR REPAIR TWICE COMES BACK NO FAULT FOUND . SKY HD AND PS3 CONECTED BY HDMI USED TO WORK BUT NOT NOW TRIED 3 SKY HD BOXES CHANGED CABLES STILL NO SOUND. BUT ONLY ON HDMI EVERY THING ELSE FINE
Connecting PC with HDMI port 1 to watch NetFlicks. Wonderful picture. No sound from TV. Only get sound from PC. PC HDMI sound test works, but not able to hear movie?????
Your setting for source of the audio is probably defaulted back to original setting in receiver. reassign audio input and problem may go away. it sounds like its not in the tv. i assume you have a receiver and are not trying to listen with speakers in tv. is this correct? if you are not using an amplifier, you may need to go to the tv menu to make sure the audio source is selected as the hdmi input. should take a bit to read thru the manual, but it ought to show you how to accomplish the correct settings.
let me know if it does not.
good luck
mark
