Question about Kenmore Sewing Machines
Won't sew when foot pedal is pressed
I recently received my grandma's sewing machine and am having trouble getting it to work. It is a Kenmore model 52. When i press down on the foot pedal the needle doesn't move - it makes a sound like it is trying to. I can sew by turning the hand wheel & the stiches are find but can't figure out why it won't work with the foot pedal.
  • Kenmore Master
  • 12,731 Answers
Since it was your grandmother's machine, it is very likely the machine has not been used in many years nor has it had any TLC. Most often, the machine will seize due to old oil that has dried out. Resist the temptation to try running the machine until the issue is addressed because the motor can be damaged. If this is the cause of the problem, you will need plenty of patience, good quality oil, possibly a handheld hairdryer, and good ol' elbow grease. But, at the end, you will have a well-functioning sewing machine.
Wheel on right side that controls the needle up and down is very tight...
Posted on Oct 31, 2017
    Top Expert:
  • Kenmore Master
  • 64,241 Answers
Foot pedals do fail and possibly your s has .
SOURCE:
  • 196 Answers
SOURCE: foot pedal dead, machine keeps sewing!
There is no suppressor in the foot control of a 425. Only the control unit, which may need to be replaced. If the machine accelerates to full speed, it may have a problem with the "stop right" board which tells the machine whether to stop with the needle up.
You could have several problems, so go see a qualified Husqvarna repairman. You may contact Husqvarna customer service to locate the best one in your area.
Posted on Apr 08, 2008
SOURCE: Needle doesn't move the problem isn't the foot pedal
I have a Husqvarna #1 that I also love. My needle stopped moving too. I was convinced it was the foot peddle but a repair person sais it was not. I discovered on my own that indeed it is the cord on the foot peddle. I suspect it has a loose wire because when I wiggle it where it connects to the machine it starts working again. Right now this is what I have to do because I can't find a replacement peddle. Can anybody help me find one?
Posted on Jul 21, 2008
  • 323 Answers
SOURCE: foot pedal assembly for White sewing machine
You only need to replace the cord if it has been damaged. It will cost less if you just take the machine , cord and control to a local technician and have him just replace the foot control. Let him test it first. A generic foot control should cost less than $30.
sewman7
Posted on Dec 29, 2008
  • 166 Answers
SOURCE: my machine has power, but foot pedal only makes needle go slowly
sounds like the contact in the foot peddle has failed try a new peddle
Posted on Jan 02, 2009
SOURCE: I have a quantum cxl.
The needle shaft sticks to the curved arm and won't come down because a piece of plastic, about an eighth of an inch thick had broken from age. It prevented the shaft from staying up on the needle arm. Open the cover, try to stitch decorative stitch and see what I mean. Purchase a package of 4-10 by 1/2 nut and bolt pack. Screw the nut all the way onto the bolt. Using needle-nosed plyers, Carefully bend the curved arm slightly, and place bolt into the hole on the top of the needle shaft. Nut will keep it in place. Lowering the needle shaft using wheel, carefully bend arm back in place. Try decorative stitch. It should work. It does for me.
Posted on Jul 02, 2009
My sewing machine does not stop from sewing when I get my foot off the pedal
one or more of the electronic components is failing . I would contact customer service for the make and request a new foot pedal
Mar 04, 2015 | Sewing Machines
Where can I purchase a used Sewing Machine Foot Control Pedal & Cord
Try eBay or a sewing machine repair service.
Search the internet, inputting:
Manufacturer + Model + "parts"
Aug 16, 2014 | Kenmore Sewing Machines
Singer confience stylist beeps four time and won't let me sew
The beeps usually indicates that your machine is not ready to sew which probably means a function has been left in the activated mode, ie bobbin winder, buttonhole function, etc. . Here are some ideas:
Why does the electronic beeper beep and the sewing machine won sew Sewing...
20 Most Recent Singer 7467S Confidence Stylist Electric Sewing Machine...
Mar 05, 2018 | Singer 7467S Confidence Stylist Electric...
Toyota sewing machine foot pedal unresponsive then goes really fast.
Try to get another foot pedal. If that works then replace.
Oct 08, 2012 | Toyota Sewing Machines
The foot pedal makes noise, but won't turn bobbin.
only having the machine check at a sewing machine repair shop can say for sure
Mar 26, 2012 | Kenmore Sewing Machines
I have a Kenmore sewing machine Model 158, 1792280. The foot pedal is not working well; I was sewing normally and when I finished, I removed my foot from the foot pedal but the machine continue sewing. I...
Buy a new foot pedal for it, probably one of the electrical components inside the foot has failed.
There are Kenmore footcontrols for sale on www.sewingpartsonline.com. You could email them to check its right for your model if it isn't listed.
Obviously I'm assuming that you are in USA with 110 Voltage and that is what your machine is. If not and your country is 220V, you would need to source it from a reseller in your own country or another with the same voltage.
Jun 12, 2011 | Sewing Machines
I have a Kenmore sewing machine Model:385.15212/15218 The problem is that I prepare the machine for sowing however when i press the pedal to sew it doesn't sew , what can be the problen?
Try to borrow another foot pedal, or try taking it to Sears and ask them to plug one of their foot pedals into it. It may be that is the problem not the machinie
Jul 23, 2010 | Kenmore 15212 Mechanical Sewing Machine
My foot pedal is really hot
Based on your description and since your sewing machine is older, the motor inside your machine is probably drawing more current to maintain the same output power and all that current is passing thru the foot operated switch.. What that means is that your motor windings may be breaking down from age and use or the contacts within the footswitch may be getting carbon on them from passing more current than the original design called for and becoming resistive ( which equates to it getting hot). I suggest you discontinue using it until you have it maintenanced to make sure you aren't risking a shock or fire hazard. Sight unseen, it's difficult to draw any other conclusion.
Regards,
Rick
Dec 01, 2008 | Singer CE-200 Quantum Futura Computerized...
Sewing Machines Logo
351 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Kelley Buchanan
Kelley Buchanan
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
