TORK Digital Interval Timer Ssa100r-24 Logo
Posted on Oct 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can i find a clock motor for a tork clock. we use these in the oilfield. the motor that i am looking at has the #'s 1A2085. And its 120v
Anonymous
Level 3:
  • Master 557 Answers
  • Posted on Oct 04, 2009
Anonymous
Master
Level 3:
Answers
557
Questions
Helped
196718
Points
1635
You will have to call Tork there # 914-664-3542. They are in New York.
Tork 1101 dial not working
Tighten the center nut on dial and see if that works.
Following link has general troubleshoot... including flip breaker fully on and then fully off... .
http://waterheatertimer.org/How-to-troubleshoot-timers.html#box
Check your wiring
Look if motor is running and turning the gears.
Stand on dry boards and wear insulated gloves when holding live electrical wiring.
http://waterheatertimer.org/images/Tork-1101-wiring.jpg
Did you buy the 101 clock motor for 120 volt... or did they send the 201 for 240volt... look at marking on new motor.
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Can a tork timer 1101 be used to control a 240 volt pool pump motor by controlling only 1 lead of the motor thus having the other lead hot all the time?
Yes: 240 volt can be controlled by turning off 1 hot leg of 240V circuit.
But the tork 101 clock motor still requires 120Volts (unless you buy a tork 240volt 201 clock motor to replace the 120volt 101)
Copy following links for handy resource and wiring diagram:
http://waterheatertimer.org/Tork-timers-and-manuals.html#1101
http://waterheatertimer.org/images/Tork-1101-wired-to-control-240.jpg
In the wiring diagram above, it shows white neutral wire running to Tork 1101 timer terminal 2. Bring this white neutral wire from any nearby 120volt outlet.
In event that you do not have this white neutral wire, you can connect ground wire to terminal 2 and that will give 120volts to the 101 clock motor.
Completing circuit to clock motor using ground wire is violation of national electric code for many reasons, however the tiny clock motor only draws 3 watts, and you will remember to bring a white neutral wire to this timer at later date so you can sleep better at night.
Additional resources:
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/images/Inside-Main-Breaker-Box-12.jpg
Gene
h
How can onr tell if timer on Tork 1101 is not working?
Is the dial rotating?
1) Copy following link for Tork 1101 product wiring and manuals:
2) Tork 1101 120Volt timer uses #101 clock motor.
If clock motor is working, then dial rotates around clockwise once each 24 hours... assuming timer is wired correctly.
3) Jan 2013, Add a comment and say what you are wiring.
15600 wiring problems
You probably have wrong voltage, or wrong wiring.
For example 15600 is 120Volt timer mechanism made by Tork and sold by GE.
This timer will not work with 240volts.
Other cause: Line and Load wires might be reversed.
Check circuit breaker.
Use non-contact voltage tester to see if power is live at timer.
Check wires at each terminal and make sure wire insulation is not under the screw plate.
Copy following link for wiring diagram:
http://waterheatertimer.org/GE-timers-and-manuals.html#15600
FYI, it is usually cheaper to buy T101 timer than GE15600, and then parts are more widely available and cheaper.
For example WG1570 clock motor for Intermatic T101 is $16.
Tork replacement motor is twice as much.
If you have 240Volt power, instead of 120Volt required by 15600, then you can buy Tork 201 clock motor and replace the 101 motor.
GE 15600 uses Tork p47 trippers.
http://www.globalelectricalsupply.com/Tork-Motors-p/motors.htm
I noticed the Tork 1104 timer box was not working. It does not make a sound. And the clock does not move. I measured the incoming and outgoing wires with a multimeter and both measure at 240V. I'm...
13 years is good run for clock motor. Timer will last longer than clock motor.
Open following link to identify timer
Tork 1104 has 240Volt clock motor
Frontier lighting sells the >> 120V Tork motor: List price 40.33/ your price 45.49
So 120Volt replacement motor costs as much as new replacement timer
http://www.frontierlighting.com/product.jsp?part=10431&process=search&show=&&gdftrk=gdfV22514_a_7c834_a_7c3267_a_7c10431
Intermatic replacement is240 volt T104 timer for $49.62 with 'free' shipping:
Also Intermatic trippers and clock motors are cheap and easily available
http://www.amazon.com/Intermatic-T104-208-277-Volt-Mechanical-Switch/dp/B000BQOX88
Crossover wiring from 1104 to T104.
Tork L goes to Intermatic 1
Tork 1 goes to Intermatic 3
Tork x goes to Intermatic 2
Tork 2 goes to Intermatic 4
Intermatic A is not used unless you have neutral wire or 277V
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
GE sells the same 240Volt Tork timer under GE model 15307 in indoor-outdoor enclosure available at Home Depot for $59.00. Year 2011, GE does not pay US income tax, but takes US profits and pays tax in foreign nations. No replacement clock motor is available, but crossover wiring is same.
http://waterheatertimer.org/GE-timers-and-manuals.html#15306
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Tork timer "time clock motor"kaput...someone set
You posted under Tork 8601 timer:
I don't think that clock motor is sold separately.
New timer costs 115 at Chapman:
http://shop.chapmanelectric.com/tork-8601-minute-120v-spdt-p-2361-l-en.html
120Volt Tork clock motor that fits some models is sold at frontier for $43:
http://www.frontierlighting.com/product.jsp?part=10431&process=search&show=&ID=,Photo.Cells...Time.Controls,Replacement.Motors
Usually the clock motor is held with 2 screws and then wires attach to screw terminals.
Look close at your screw terminals to see clock wires.
Normally timer mechanism snaps out of box and clock motor is on back of mechanism.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
I have an Intermatic T103 DPST timer installed now (120v). The clock mechanism has failed. I bought Tork 1103 guts to replace it. The wiring is a bit different. Can u map for me which wires go to which...
T-103 has 120V clock motor with 5 terminals A 1 2 3 4
Tork 1101 has 120V clock motor with 4 terminals L 1 X 2
T103 is DPST and can control one-or-two 120Volt loads, or one-or-two 240Volt loads.
Tork 1101 is SPST can control one 120Volt load
Common ground between these timers one 120 Volt load
Changeover for one 120 Volt load:
White wires T103 terminal A go to Tork terminal X
Black wire T103 terminal 1 goes Tork terminals L and 1 (there is brass connector plate that connects L and 1 - if connector is missing, jumper between L and 1)
Black wire on T103 terminal 2 goes Tork terminal 2
If Load requirement is greater than T1101, Grainger sells T103 clock motor for $16
http://www.grainger.com/Grainger/INTERMATIC-Time-Clock-Motor-1PNK1?Pid=search
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
How to wire T103
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T103
T1101 wiring manual
http://waterheatertimer.org/pdf/110111021103WIRING.pdf
I have a w100 tork timer and i would like to know how to repair it and how to position the time pointer.
How to position time pointer
Rotate disk counterclockwise until current time lines up with silver pointer
Place trippers on outer edge of dial > trippers are reversible so one side of tripper in ON > flip tripper over and it is OFF.
Disk rotates with passing time, trippers click lever ON and OFF at set times
How to repair W100:
If dial is not rotating, then clock motor is bad >> W100 uses 120V clock > check markings on clock. Internet shows Tork T101M and T201M clock motors, but unclear if either clock matches W100 timer.
If dial rotates but trippers do not turn Load on-off then buy P-69 trippers
If manual override turns Loan on-off then electric circuit is working
If manual override does not operate Load, then check electric circuit or Load (light bulbs burned out)
If manual override is sluggish or stuck, and doesn't click crisp and clean, then timer is worn out or needs to be cleaned.
Product Manual:
http://waterheatertimer.org/Tork-timers-and-manuals.html#W-series
Link above shows manuals
Manual for W100 does not show specific clock-motor model
To buy parts or another timer
P-69 trippers available on web
Tork T101M and T201M clock motors available on web but unclear if they match W100
http://www.weisd.com/store2/tork/torktimer1.php
Page above sell W-series time dial part #70159 for 72$.
Page does not include photo, so unclear if dial includes clock-motor, or if voltage is 120V
Tork accessories pdf shows part #70159 as dial for W, with no other information
Same seller shows new W100 sells for $148.
Replace Tork with Intermatic, buy T7401B
Website sells T7401B for $114
T7401B is 120V timer and has 120V clock motor
http://www.1000bulbs.com/product/3377/ELEC-T7401B.html
Manual for T7401B
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t7401b%20-%20english.ashx
Timer keeps time, but sticks at tripper points
1) Clock motor needs replacement:
Link below shows timer and wiring manuals.
2) 120Volt Clock motor sells for $43 at Frontier lighting
3) New Tork 1103 sells for $55. Just swap out insides without changing box.
4) Intermatic crossover for Tork 1103 shows Intermatic T103 timer.
Amazon sells T103 for $50
http://www.amazon.com/Intermatic-T103-120-Volt-Mechanical-Switch/dp/B000LDIDBY
Top TORK Hardware & Accessories Experts
vince
ADMIN Andrew
ADMIN Andrew
Are you a TORK Hardware and Accessory Expert? Answer questions, earn points and help others
