Computers & Internet Logo
Posted on Oct 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i connect an external microphone to my philips freevents x55. only the built in microphone is working. an externally connected mic does not over-ride the internal one?
Anonymous
Level 3:
President:
  • Master 2,049 Answers
  • Posted on Oct 04, 2009
Anonymous
Master
Level 3:
President:
Answers
2049
Questions
0
Helped
1488847
Points
8420
Your default recording device is still set on the built-in mic.
In Microsoft XP...
Choose Start > Settings > Control Panel and double-click the Sounds and Audio Devices tab
Select the Voice tab and choose the the appropriate item in the Voice recording Default device pop-up menu.
In Vista, choose Start> Control Panel > Sounds and click on the Recording tab.
In both instances, choose your external mic as the default.
Windows XP 1 Choose Start > Settings > Control Panel and double-click theSounds and Audio Devicescontrol panel.
2 Select the Voice tab and choose the the appropriate item in the Voice recording Default device pop-up menu.
2answers
How to disable Dell latitude E5500 built in mic so you can connect an external mic?
Just plugging in the external mike into the jack should AUTOMATICALLY disconnect the internal mike.
How do I connect an external microphone to my Toshiba Salellite Laptop computer?
Right click over speaker icon (next to your clock right bottom corner), click recording devices. Clic on your external mic, clic on properties, at bottom on the new window select "use this device (enable)"
Got a MacBook Pro...problem recording with external microphone
Hi
... sound issues like you are having do pop up occasionally ... the best thing to do is to reboot the system ... sorry.
Cheers.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ronald_f3c54257e2cc2559
1helpful
Can I connect an external mic to a JVC Everio GZ-hd3ek? Thanks
YES - t built in microphone and the appropriate ports to allow connection of an external microphone.
GO to some eletronics store. Tell them you need a MIC with a MINI-JACK connector. mini jack is the end of the microphone - its really just the size - so.
Hope this Helped x404x
2helpful
Connecting external microphone to imac g5
Get yourself a great little gadget called iMic. It's a usb connector that adapts to let you used your headset mic and the mac system os will recognize it very well. Works good .
Costs about 24 bucks or so..
K
3helpful
How to record sounds using external mic on acer aspire 4315???
go to the sound recorder available at start ---> programs ---> accessories then entertainment ----> sound recorder.
click on edit -----> Audio properties -------> default input device and change it to the external Mic you have connected.
let me know if this helped, good luck :)
External Microphone - Not working
good day
have you tried inserting the microphone plug to the red/pink socket in your sound card?
Regarding the canon hv20 camcorder. When using an external canon MIC a) How do you know the mic is working and you are not picking up sound on the internal MIC b)On connecting the external MIC an icon...
If you put the camcorder in manual mode, there is a microphone sensor that will move when sound is picked up by the external microphone. In manual you can keep everything else automatic. The off for the mic means that the built in mic is turned off when an external mic is attached.
Microphone
the external mic must be unplugged for it to work and you need to reconfigure the internal mic if it doesn't work... there should be an option for this under start>settings>control panel> audio> microphone
1helpful
External mic
No you can't !! This unit only has an audio out but the mic is built into it. You have to speak into the WBT210 when you connect to a phone call.
Grand Canyon Tech
Grand Canyon Tech
