Circuit Board Medics can rebuild the CCU with upgraded components to eliminate the F14 error and prevent it from happening again. Find more details and contact information at www.CircuitBoardMedics.com.
This video shows how to remove the CCU from the machine:
Here is what f 14 code means.
EEPROM Error
The Central Control Unit (CCU) receives it's data from an EEPROM on board the CCU. If there is an error reading this data, it will cause this error.
Here is what to look at.
Good luck
Hey friend, thanks for your post!
I see that your Electrolux wall oven is displaying an "F14" error code. "F14" stands for display tail missing, which means you could have an issue within your main control board or keypad. I would perform a reset on your appliance which can be done by flipping your household circuit breaker off for roughly ten minutes. If that does not correct the issue I would suggest seeking a professional to come out properly diagnose and repair your appliance. I hope this is helpful. -Matt
