General M-D Building Products  Purpose Box Beam Level, 24" Logo
Posted on Oct 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can a building act as a climatic filter? How did it come that man should build? I have been giving assignment and i have done my best to get answers for those two questions i have asked but i have not been able to find solutions to these question. I would be happy if you could help me find solutions to them.
Anonymous
Level 2:
Scholar:
  • Expert 75 Answers
  • Posted on Nov 06, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
75
Questions
0
Helped
15140
Points
115
You want to filter the climate? Which part, how much, what do you want to remove from the climate? Man builds for something to do so that he doesn't have to think about his precarious position before GOD.
My kodi 17.6 wont take any builds why? Every build I try to install fails and wont programe. Some say check log some just stop programming right after it starts.
If your getting an error with Kodi Krypton I would suggest taking a look at the repositories and if they are still working. Sometimes when the repositories are down you will get an error and the build wont be install. Be sure your not using Ares Wizard niether to install the builds, as Areas Wizard for build installation went down as well. If your looking to install a build check the link I posted below. It shows you the best kodi builds for 2018 and gives full tutorials on how to install them. If you have any trouble installing them the help is great at that site as well. Hope this helps and you get your in build installed successfully.
Best Kodi Build List for 2018 Must Read Before Installing BestBox
1helpful
Which ipad has this serial #,Is this for ipad 1,2,or3? DN6FXJPYDKPH
Serial Number: DN6FXJPYDKPH
Model:- iPad 2 (WiFi)
Codename:- No codename assigned.
Build Country:- We don't know where this unit was built.
Build Year:- This unit was built in the first half of 2011.
Build Week- Week 26 (June)
Production Nr.:- This unit was number 2038 to be built that week.Serial Number: DN6FXJPYDKPH
http://www.appleserialnumberinfo.com/Desktop/index.php
1helpful
Hi i have a Isuzu kb 300tdi lx when i start the vehicle after standing for 6 hours and more the oil lights burns for +- 3 seconds what can be the problem
Your oil pressure in every engine has to build up! What this is telling you is the bearings and oil channels have lost the oil pressure! Don't be alarmed this is a normal occurance! You can use a higher viscosity depending on where you reside? In warmer climate states a higher viscosity oil can be used like 10w30 or just 30w oil in colder climates a lower viscosity can be used like 5w or 10w generally the oil pressure taking 3 seconds to build might be the oil is due to be changed as the viscosity has been degraded or the oil pump has wear on it but as long as your pressure climbs and doesn't stay at zero you are safe if it goes above its normal position you have either a spun bearing or a stopped up oil filter not allowing the oil to travel and build up pressure!
2answers
We put in 2 fans under a canopy by the tennis courts, however, it is not giving the cooling effect we were hoping to achieve. It is open on all 4 sides. Would lowering the actual fan or changing the speed...
Are these box fans that you are trying to form a wind tunnel effect? If so, you be better off building "tunnel" for them. What seems to work the best (a poor man's air conditioner) is to build a push - pull tunnel with high volume fans. If you mount a drip system with a fabric (like filter material) where water saturates the fabric and then is exhausted out towards your tennis courts.
BUT you need large high volume fans for this to be effective for more than just a few feet away from the unit. BUT then it might also affect the tennis balls on the court. So it depends on what your objective is. If it is to keep watchers cool then it would work, if it is to cool the players then it could also affect the "play"!
Note: Camoflage neting is an effective way to shade something but not affect airflow.
1helpful
I need to block certain extensions from being able to dial long distance
Best way to do that is to sit down with the manual and look at programs 400-408. At a minimum, if you restrict 1 and 0 in a table and assign it to your extensons in 405, those phones can't dial long distance. That's fairly worthless in today's calling climate when some carriers let you dial just 10 digits or you have to dial 1 for any local call outside your area code. 404 lets you build 8 tables of 10 number sequences each for restriction and 407 lets you build 8 tables of 10 number sequences for allow. For example You could put 1 HOLD HOLD HOLD (hold is the wildcard) in one table and entry of 404 with traditional dialing and that would restrict all 1+ long distance. Then, in 407 5 of your entries in one table would be 1800, 1888, 1877, 1866 and 1855 to allow toll free calling. These tables get assigned to extensions in programs 405 and 408. A simple restriction (ie local calls only, internal calls only) get assigned in 401. There are some other tricks and, above all, remember that you have to keep 911 availabe for access and allowing 0 is never a good idea because 0 alone will get the operator and that defeats the purpose of toll restriction.
Other tricks involve custom CLASS codes. You need to account for the clever worker who dial *67. That gives them second dial tone and they can dial the world. It would be easy if you could block first digit *, but you ought to allow *57 for nuisance call trace. If you have the above where long distance is dialed with only 10 digits, then you can always start with HOLD HOLD HOLD in a table and allow 911 and the local area code in an allow table. The table digits can be up to 12 so you may have to go to 6 digit screening in allow tables for local exchanges. In my area, we have 10 digit dialing and 419352 419353 419354 (among others) along with 567213 are local calls. If I were programming a customer 6 miles to the North, there would be extensive programming in both area codes.
Outside of that, it's just a function of analyzing your local calls, area codes, how a call is dialed, and building your tables. We do this with billing by the hour :-)
Carl
How often do i need to replace my fuel filter?
SIMPLE MAINT SCHEDULE , IS CHANGING IT ONCE A YEAR, but it depends where you live, If this truck is a diesel & you live in a northern climate, change your filter once a year but not until you know for ceretain that you are buying winter grade fuel, ie: nov
Reason for this is that there will be wax/parafin build up in the filter that your ran on the summer fuel, it can congeal in the filter in winter becasue of this build up. If you replace the filter in late autumn, then tat filter will not have a congeal problem because the there hasnt been anything but winter grade fuel through it, , and its safe to run all next summer , but the summers residue will cause problems next winter , so change again in late autumn .
How can i?
In a day or so I will give you a download link that will give you software you can use to build your own software I just need to know your operating system, like XP, Vista, Mac, etc... Just respond to me to tell me that you are interested, okay?
All The Best,
RCF
2answers
Voice Mail
if you can not transfer a call to voicemail, there isnt a mailbox made. If you transfer a call and it doesnt go to voicemail, then there isnt a mailbox OR it isnt assigned to the voicemail group.
To assign a phone to go to voicemail (if there is a mailbox made)
at extension 10 or 11
press feature 00
LEFT intercom
Left intercom
#310 (auto VMS cover)
group 7
enter extension number.
If it says 2 not assigned, press "1" so it says assigned.
Press feature 00 when done.
If it still does not work, you need to build a mailbox. Will need to know EXACTLY which voicemail it is in that case.
3answers
Router stops responding with red alert light turned on
I had the same problem since a bought it last week and I was going crazy. Install this firmware and everything will work fine:
http://booobi.googlepages.com/uperJerry_V2.8b4_Worldwide_A.rar
Top General Measuring Tools & Sensors Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a General Measuring Tool and Sensor Expert? Answer questions, earn points and help others
