If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, the "F05" error code will be displayed.
Possible Causes / Procedure
1. Unplug washer or disconnect power. 2. Check the water temperature sensor. Check connections to the water temperature sensor. 3. Check resistance of heating element, if present on this model. (abnormal = infinity).
Replace any parts that is malfunctioning or defective.
F05 means pressure switch jammed on full.
Remove the lower rear panel of washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove and clean plastic fillter inside hose.
Reassemble and test.
No d5 there is F05 Du> and DL The F05 is water not being heated . The D is for door switch not locking or unlocking .Must have complete model from washer to be sure
Hi Thanks
for using FixYa. It generally happens when during the water heating step in the
wash cycle, the water temperature sensor value is out of range then the
"F05" error code will be displayed on the washer screen. To resolve
the issue unplug or disconnect the power of the washer from power socket and
mains. Check the water temperature sensor and its connections. If available on
the washer you have, check resistance of heating element and replace the components
which have gone bad.
Please do rate the solution and revert for further assistance. Thanks Rylee
Error code F05 means water level switch is stuck on full.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean plastic filter inside hose.
Refit and test.
Remove and clean filter inside hose.
Refit and test.
Please rate my solution.
Thankyou.
Error code F05 means pressure switch jammed on full.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to bottom of drum.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve the problem.
Please leave feed back.
Thankyou.
I hope you find this information helpful. I have seen this error code generated by something as simple as a loose connector on the NTC sensor. Hopefully, you can resolve this with no expense. If you do require any parts, however, you can locate parts with illustrations at searspartsdirect.com or repairclinic.com. If you require further assistance, please let me know.
