Yes one of the lowest grade tablets ever made but here is a video that might help you
please make sure htis unit is not a stolen one and that you owned it from day one Android 2 3 on Archos 7 HTv2 CyanogenMod 7 Rockchip 2818 port preview
SOURCE: Just got Archos 5 goes into error 101...
Hi there, these instructions are for the archos 705 but they are the same for the 605.
A) Download the firmware from Archos and save it to your desktop (Make sure the file name on the desktop hasn't changed from the original download file name)
B) The Archos 705:
1- Connect the unit to its power source.
2- Start the unit in recovery mode: Press the TV button first then the power on/off and keep pressing TV button (do not release it)
3- The recovery mode will start (the screen that asks for repair or format etc…)
4- Select "Repair" by scrolling up and down with the TV Button (it is all explained to move through the menu at the top of the Archos screen) (Do not press "Format" at any time)
5- Now that you are on "Repair" select it to validate your selection
6- The unit will go to "Plug the unit etc…" plug it with the USB cable to the computer
8- Wait until Pc should recognizes your Archos (around 5 seconds)
C) Computer
1- From your computer select the firmware file you downloaded from the net and put it in your Archos (in the root folder, nowhere else, where it has the folders, music, videos, pictures etc… as a file)
D) On the Archos 705:
1- Select "Ok" on the Archos (on & off button) shortly to select and confirm the file is now on the Archos
2- you are done! The Archos 705 should now read through the file you have transferred and repair the system
3- DO NOT DISCONNECT the power cable until the process is finished
4- When done safely disconnect (as you usually do, for Mac trash the letter of the Archos to the bin or for PC's: right click the green icon bottom right of the screen for xp & vista)
5- Press on/off button to reboot
Your unit should restart with a fresh repaired, updated system like day one.
SOURCE: My archos wont connect to my computer
i had this problem. you have to use a high speed usb port (2.0 i think) which is normally in the back of your computer and then it should be detected
SOURCE: Archos 5 constantly rebooting after reset
Heyy i have the same problem! Can u let me kno if u ever found a solution? thanx
SOURCE: archos 5 internet tablet won't
Hello wilko1974, This has been an on going issue for Archos 5 users. The new youtube supports flash 10.1+ and the Archos 5 only supports 9. Unfortunately there does not seem to be a clear cut solution for this issue. Archos has not released a firmware update for this and with their new devices it there support for older devices has lowered. I have found that choosing the lower play button that appears over a video plays on Archos more often than the top button. I would recommend trying this and seeing if you get better results. Another possible solution is to open the video in a new window with the link on the top right of youtube video. This however is not on all youtube video pages and with the currently layout is on accessible when the video submitter enables it. It also help to have the latest firmware updates that can be done directly on your device. Hope this helps, Greg
SOURCE: How can I watch youtube
You have to get the corresponding application, in example, YouTube Downloader - VideoBox, please check the link below:
http://appslib.com/applications/app.html?ida=9775
