Garmin Edge 305 GPS Receiver Logo
Posted on Oct 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I charged my Garmin 305 and the screen read fully charged. I went to turn it on and there is no power. Now I can't even charge or download anything. It is fully dead.
John Egan
Level 2:
  • Expert 85 Answers
  • Posted on Mar 27, 2010
John Egan
Expert
Level 2:
Answers
85
Questions
0
Helped
32358
Points
114
Attach your unit to your computer and go to garmin.com, download webupdater and then go to my dashboard on garmin and follow the instructions
GPS unit won't charge when placed on cradle and plugged in wall
You may have to replace your battery, these go faulty often, even though they seem OK.
17helpful
Ive not had my garmin 305 long, it will not charge or turn on.
This might just need a reset. To reset the Forerunner or Edge 205/305:
  1. Connect the device to the computer using the USB cable
  2. Press and hold the mode and reset (lap) buttons together for 10 seconds
  3. Release and wait for 3 seconds
  4. There should be some indication of battery charging (either Finished or In Process)
  5. Power the device on while keeping it connected to the computer
In addition, please make sure that the device has the latest software version available by downloading and running the WebUpdater program. To update the software, please use the following link:
http://www.garmin.com/products/webupdater/
1helpful
Garmin Edge 305 will power off in a min or 2 riding in afternoon
This is a generic problem with the 205 and the 305 go to MTBGurublog and look up 305 problems there is a blog that shows how to open and fix it
My Garmin forerunner 305 recently got immersed in
I have read in some other posts about the unit only working while being plugged into a USB port. My guess is that the battery is in fact shot and the unit will only run off the USB port while plugged in. Submersing in water is not a good idea. On the back of the unit there are some small holes for the speaker. These speakers corrode from sweat and eventually quit.
16helpful
Garmin 305 wont power on, wont charge on cradle
Same thing happened to mine. Put the unit in the cradle (just like you are going to recharge it) and press the reset and mode button at the same time for 3 seconds. This will "wake" the unit up.
1helpful
My garmin will not turn on and its fully charged
The reset button fixed the power problem. Thank You, Thank You!!!!
1helpful
Garmin not working even after same reset and mode button reboot
Not sure to catch all you did. Apparently your battery is discharged. So you should plug your device on charging via USB. Wait for a while (1 hour) then reset the device (Hold mode and lap/reset for 10 seconds, release, then hold start for ten seconds
9answers
Will not start or turn on
I have had the same problem several times (as well have some friends).
This resolves it EVERYTIME though... at the SAME TIME, hold the BOTTOM LEFT front button AND the Bottom LEFT SIDE button (this reboots it). Then just hit the power button... I am sure you will see that it powers right up.
8helpful
Garmin Forerunner 305 usb cable won't be read
The problem is probably not with the USB cable if the GPS wont even turn on. The older firmware of the Forerunner 205 and 305 have a problem with locking up. This causes the Forerunner to look completely dead. There is a reset procedure: push the mode and reset button at the same time and then let go and hit the power on button. If it powers on that is the problem. Go to the Garmin site and load the newest rev. of firmware into the Forerunner. Fixed mine and a few friends with the same problem.
I do however have a cable problem. Sometimes my PC will come up with unrecognized USB device and my 305 wont talk to the PC, it does charge. It is the cable or dock for sure, because I have tried a different cable/dock and the 305 has no problem. This is the reason I ended up here. I hope the lock fix works for those with the above problem.
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
