My phone powers up straight to boot loaderexactly the same as you. Can you tell me what you did next to get it up and running.My phone powers up straight to boot loaderexactly the same as you. Can you tell me what you did next to get it up and running.
my motorola is also saying boot loader and press ok to program it started by freezing in calls it got stuck as i talk and now its stuck on bootloader please help me some how i have spend $1800 on this phone by getting it from england thanks.
AnonymousOct 21, 2008
how can i change my motorola bootloader?
AnonymousNov 06, 2008
Stuck in bootloader modeStuck in bootloader mode
You can't post conmments that contain an email address.
try using RSD 2.4 or higher and flash it with R749 MP, keep in mind RSD is not easy to find and since it is considered a warez it is not allowed to be posted hope this helps
if the phone says "bootloader" or any error like that on the main screen it means the software has been deleted. when a company makes a phone i.e. motorola or samsung or any other its a blank plastic shell. they then load software on it for each provider the phone is made for. when it says bootloader that means that its back to a blank shell. you can call motorola and they can try to reload it or call the cell phone company you purchased the phone with and process an exchange if its under warranty.
This means that the phone firmware is corrupt - you can try to reflash it using Motorola software update, but it might not work for a phone stuck in bootloader mode:
Sounds like the firmware has gotten stuck it was a common bug in some of the v3 firmware versions. Pull the battery, replace it and then power on while holding down the # and * keys it will go into bootloader mode. Once on the text bootloader screen you can use flashback (google for it) and flash a more current firmware which will fix the phone.
Oh the lovely Bootloader screen? If you take it to your service Provider they should be able to reflash the phone back to working order for you. Just ask them to do it though.
hi have two razr v3x phones and both wont turn on so i turned them on using boot loader and they both say same:
battery ok
ok to program
transfer mode:
serial rs-232
please someone tell me what next
help?
I have the same problem
ok to program
transfer mode:
serial rs-232
the same problem...
my phone is stuck in bootloader...
Hi!
My phone is stuck in "bootloader usb init"... and won't pwr up? Any advise?
Thanks!
