Hitachi 60V500 60" Rear Projection HDTV-Ready Television Logo
Posted on Dec 22, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hitachi 60'' rear projection wont power on
My tv when powers on stays on for a split second and when took back cover off i found 5 green leds lit up but 1 green led did not lite up... then red led blinks on the board next to red led says Protect LED,,,SO i am assuming tv is in protect mode... If it is a Fuse how do i identify it and where is it located?...
Anonymous
Level 3:
Genius:
  • Master 1,153 Answers
  • Posted on Dec 22, 2007
Anonymous
Master
Level 3:
Genius:
Answers
1153
Questions
0
Helped
324844
Points
2386
Read ctechnicians.com
1helpful
Tv wont turn on
With set unplugged remove rear cover and follow the power cord to the fuse--good or bad? This set should also have some led lights there that are green or red---look to see if any are lit or if when plugged in with back removed which come on or go off instantly, the reason I ask is those are each tied to a voltage source and will point to where the problem MAY be.
Our 60sdx took an electrical hit, and now, when we turn it on it goes to protection mode. What do we do?
All of this involves some testing:
I would remove back cover and look at the several green LED's on the board and the red one as well.
The red one should be lit and the green ones should light when set is turned on; primitive self check as each green one is tied to a voltage in the set's internal power supply.
Usually when an electrical hit parts at the in to the power supply get taken out.
Got a red led lit on the board?
This like all sets has standby power supply built into it: some sources are active 7/24 even if set is off and they usually take the hit.
Not knowing if you have a voltmeter and or know how to check I would suggest look at the led lights on the board.
Before you rate this information LET ME KNOW WHAT YOU FIND.
Sd Tech
Power light comes on but tv has no picture or sound
There are four leds used for diagnosing inside the TV 3 are green and 1 is red. Are they lit up?
1helpful
2answers
I have a 56' that wont show picture
Power board is bad.. I had the same issue.
60SDX88B. No video, No sound. DP06 Protection
not a solution but i have a 50gx30b doing something similar, no picture no sound, 3 green leds are lit up on the main board and then one red led lit up also on main board, front panel red led stays on for about 30 -50 seconds and then it all shuts off, I then have to unplug and replug to get the same results.
Hitachi 50ux26b
Good day, 1gary;
Hitachi has LED’s, green ‘lights’ and a red light to determine what circuit may be the problem; after removing the back of TV, bottom only, plug TV back in and observe which LED’s come on …..BUT most important which LED’s don’t come on; locate and note number, EG; DP37 and etc.
Good luck, big IRISH. Ps let me know.
2helpful
2answers
Will not stay on
RED light is protect circuit = do not disable !
Look for C702 near flyback transformer - might be hidden in
glue = check it = if shorted, replace 102K / 2KV with 3KV =
Sony part # 1-161-754-00 and replace E994 pico fuse.....T.
2answers
No power on Hitachi 50UX588
Most likely have a regulator problem. Remove rear cover, look down on the main chassis, turn tv on watch the board to have some colored led's lit, usually a red one and couple of green. If the red is out, its your regulator, if a green one other problems off the circuit with green led are causing the tv not to power up.
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
