P0442 Evaporative Emission Control System Small Leak Detected
P0446 Evaporative Emission Control System Vent Control Circuit Malfunction
You should replace the VAPOR CANISTER PURGE REGULATOR.
Go to autozone and have them do a scan it is free and will help id the exact cause & fix
If you need further help, I’m available over the phone at https://www.6ya.com/expert/michael_00678fd4800d19c5
CODE PO442 IS EVAP SYSTEM MEDUIM LEAK DETECTED.CHECK VACUUM HOSE CONNECTIONS OR SWITCHES HAVE COME A LOOSE OR MALFUNCTION.ALSO THE EVAP PURGE SOLENOID OPERATION HAS MALFUNCTIONED.
