Computers & Internet Logo
Hale Browne Posted on Oct 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello, My Asus P4P800 SE motherboard has stopped recognizing my monitor LG Flatron 22'' . I have 2 PCs connected by a KVM switch. When I boot machine A, the monitor stays black. When I put the video card in machine B it works. VisionTec 1500 video card. OS = Windows XP pro. Can you help?
Anonymous
Level 2:
  • Expert 41 Answers
  • Posted on Oct 04, 2009
Anonymous
Expert
Level 2:
Answers
41
Questions
0
Helped
12330
Points
108
Test both machines one at a time on the monitor without the kvm switch then hook up the kvm switch to machine A if all works well power off then hook up machine B and see what happens, it maybe that the switch is set to the other pc than the one you want to use first so the screen stays black untill its switched over
P4P800 SE - UAYZ BIOS
Hello you can find drivers and the manual here:
http://support.asus.com/Download.aspx?SLanguage=en&m=P4P800%20SE&p=1&s=15
You just have to select your windows system.
Any file from here needs to be unziped, before you install the driver.
Good luck
P4P800 SE not bootable on sata
Hello download the manual here:
http://www.asus.com/Motherboards/Intel_Socket_478/P4P800_SE/#download
Please select your windows system
Open the manual folder and click on global for download
Unzip the file and you need adobe reader to read the content
Take a look in the BIOS and under advanced you should be able to see the motherboard settings for the drives. Make sure that the board is set to use ENHANCED settings and not LEGACY, then go to the BOOT section and make sure the SATA drive is the first drive.
Good luck
2answers
PCI Simple Communications Controller, seem not to function
Hello my friend
First your motherboard does not support windows 7 and the maximum ram capacity is 4GB DDR400/333/266 non-ECC DDR SDRAM memory
Second you can go here and check which memory your motherboard supports
P4P800 SE Memory QV
http://dlcdnet.asus.com/pub/ASUS/mb/sock478/p4p800-se/P4P800_SE_QVL.pdf
Third you can try updating your Bios,more information in your manual
MANUAL
http://dlsvr.asus.com/pub/ASUS/mb/sock478/p4p800-se/e1886_p4p800_se.pdf
your motherboard details is here
http://www.asus.com/product.aspx?P_ID=YNlDkmz5gSNpiCr6&templete=2
Good luck
I'm trying to boot to USB from my P4P800 SE. The problem seems to be that I have to enable some type of emulation in the BIOS. Is there any way around this?
some bios are able to boot with the (f12) key and then you pick which device you wish to boot with otherwise you must enter the bios and set the first boot device to boot your usb
Does ASUS P4P800 deluxe support high density memories
Here is a link to Asus' Qualified Vendor List of RAM modules for your motherboard. I do not see it mention high density RAM. You would need to search the specs on the modules recommended to be sure.
ASUS QVL
In case you don't have the manual, here is a link for it too:
ASUS P4P800 Deluxe Manual
Memory info begins on Page 2-10. Again, there is no mantion of HD modules.
Trying to fix old computer
remove the external display card boot ur machine with on board then disable the on board display and then install your external display card and then connect it to the monitor
2answers
No. Your board can support any AGP video card.
But it does not support any PCI-E cards.
4helpful
Try to have the driver of the motherboard p4p800 se sound driver
hello,
You can find your drivers here: http://support.asus.com/download/download.aspx?SLanguage=en-us
Pls input necessary data about your motherboard.
may this help
melnavz
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
