Tried to use stove this morning - heat top worked for a minute or so and then stopped. We weren't immediately present when it went out, but came back to check food and noticed burner was warm.
Turned off burner and the clock turned off.
Oven dial does nothing.
Clock turns back on when burner is turned on (and maintains the same time as when it first stopped working).
Right now, I just turned the burner on, but no heat. Lights are functioning, but no heat at burner.
Where do I start?
Check your fuse / breaker box make sure you have power (sounds like you dropped a leg of power) make sure breakers/fuse is on/good flip it to off the to on if oven don't work then take a look at the cord to the range check power at the wall then open where cord goes into range check power or you may even find the cord burnt in there if so replace all damaged wires good luck
Checked breaker box per your info.
Power is still at the range, as the lights come on when the stove top is turned on...but as soon as stove is turned off, clock/display shuts off as well (where it would typically show the time).
Second attempt: when pulling the range away from wall, there was sparking near where the cord enters the housing. Unplugged and took panel off - red wire was totally fried.
You had it right on: "...may even find the cord burnt in there..."
Thanks!!
- matt
Turned JBP80 on to preheat, came back a few minutes later and display was blank. Oven was warm but no longer working (oven and burners). Checked wiring and no apparent problem. Can get clock to come on but when I turn a burner knob (light on but no heat) the clock goes out.
I have the exact same proublem it is weird that there hasn't been any r call. I have only had my stove a year and a half.
All burners and oven stopped working in the middle of dinner. no codes present
burners work display don't work so can turn on oven
