How i can set up a casio wave ceptor WVA-104H
SOURCE: casio wave ceptor WVA-105H
Casio is a great watch company
you can get online manuals anytime
http://www2.casio.co.jp/manual_pdf/wat/en/pdf_search.php?MODULE=2734&submit.x=49&submit.y=8
SOURCE: How to set the hands to match the correct digital
Setting Digital Time
Push the lower left button to move to the Daylight Savings Time portion of the watch. Use the lower right button to toggle between "On" and "OFF."
Press the lower left button twice. The hours unit will start blinking. To advance the hour, press the lower right button repeatedly until the correct hour is displayed. If you need to move the hours unit backwards, press the middle right button until the correct hour is displayed. When the hour is set, press the lower left button to switch to minutes, and use the same commands to change the minutes unit.
After the time is set, press the upper left button to exit the digital time setting function.
Analog time adjustment is completed using the lower right button. Every time you press the button, the analog time will advance 20 seconds. If you need to make a big change to the analog time, press and hold the lower right button to make the hands move faster. Once the analog time is set, press the upper left button to exit the analog time setting mode.
SOURCE: need user manual for casio
Set your city to DEL (Delhi).
If you haven't got instructions on how to do this, you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
