Several GSM712 Netgear Switchs where donated to our school. However we do not have the passwords to manage them. How can I restore to factory defaults or recover the password?
Netgear GSM switches have an RS232 serial console port. Connect to that using Hyperterm, PuTTY, Xterm etc. at 9600-8-N-1, and power up the switch. Early in the boot process, it will give you a choice of normal operation, or the boot menu. Select the boot menu before the time runs out (usually a couple seconds), and one of the options will be to reset the switch configuration, including the password.
As far as I know, there is no way to recover the password and leave the configuration intact.
As far as I know, you'll need Netgear's help to recover the passwords and they'll only help if you have a Premium support contract.
Try "1234" as this is the default if password protection is enabled.
You can hit the factory reset button on the router to reset the router password.
Donate
http://www.helpowl.com/p/D-Link/3350SR/Research/20945?search=des%203350sr%20setup
DES-3350SR Layer 3 Fast Ethernet Switch Users Guide reset Restrictions Only administrator-level users can issue this command. Example Usage:
To restore all of the switchs parameters to their default values: local>reset config Command: reset config Success. local> login Purpose Syntax Description Used to log in a user to the switchs console. login
This command is used to initiate the login procedure.
The user will be prompted for his Username and Password. none. none. Parameters Restrictions Example Usage: 46
hope this helps
