SOURCE: citizen 0510
The battery model number that needs to be replaced should be located on the outside of the back side of the wrist watch and if not you can always open the watch up and look and see what model number is on the gbattery itself. If the battery is not the problem then you may need to take your watch in and have a professional person to look at it. Hope this helps you.
SOURCE: need to activate my new Locman 1974 self winding watch
this website may be helpful to solve your problem
http://www.finewatchmaking.com/
SOURCE: keeping 2008 breitling cockpit watch running
You have to wind the watch till it is fully wound (significant resistance should be felt).
It doesn't matter how many times you wind it (1 or even 40) - what matters is the strength of the spring.
Do as follows:
At any time in the morning wind the watch up till you feel there is no more winding left (should be quite tough). Memorize the time you did it.
Leave the watch (or wear it) till it stops completely.
Count the hours your watch did work (from the time you wound it).
Now you know exact power reserve for your watch.
It is advised to wind the watch 2-3 hours before the power reserve is gone.
Rate me.
, please.
SOURCE: Dont know how many time to wind it
until it begins to feel just slightly taunt,Do NOT over wind a wind-up wrist watch, if its a self winding you should just have to walk in it to wind it. here is a link to a pdf of your manual which has winding procedures, Good luck Jon click here
SOURCE: how long does watch run after winding
35 hrs if you do not move it at all. If you wear it continuously you will never have to wind it again!
