Clark Forklift Horn Button Switch  , Cat Etc Logo
Posted on Oct 03, 2009
Clark Forklift GPX25 will not shift into reverse. Unit was working fine a month ago. Do not use the forklift that often about once or twice a month. Unit will work in forward, but not reverse. Even when the unit is in netural it still wants to go forward.
dmitry Gabnir
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 17, 2016
dmitry Gabnir
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4628
Points
I have the same problem, gonna try check it out and will let you know if I find out anything. Please post if you have found a solution ? Thanks
  • 1 more comment
  • Willem Erasmus
    Willem Erasmus Dec 07, 2017
    Did you find out what the issue was? Ive got the exact same problem at the moment
  • Keith Novosel
    Keith Novosel Dec 29, 2017
    just ran into the same issue if you guys figured it out please post it thanks
  • Antonio Flores Feb 21, 2018
    I also have the same problem. In park goes forward, neutral goes forward, reverse goes forward
Anonymous
Level 1:
New Friend:
  • Posted on Apr 10, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4628
Points
I got the same problem and same model, what's going on with Clark forklift, I look for the new transmission all over internet but can't find any. if any body know what wrong please tell us what to do. thanks a lot. TMV
How to change horn on clark gcs15 forklift
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem. Clark GCS GPS Standard Forklift Factory Service Repair Workshop Manual...
HOW TO CLEAR CODE CANBUS ERROR 2 ON CLARK FORKLIFT?
I have clark forklift not starting
error: canbus error 1
2helpful
L.P. powered forklift will not move in reverse. Forklift will lift, shift, and move forward, but will not move in reverse. While in reverse the engine will rev up, but there is no reverse movement...this...
Check for blown fuses and check the reverse solenoid. You can swap the forward solenoid with the reverse one. If it works, then replace the solenoid.
I have a toyota 5fbe15 forklift set at 36 volts. The problem i'm having is that every now and then, it will shift at normal speed, 5-6 mph and slow to 1 mph. Usually happens if it's shifted from foward...
Good morning.... sorry I have a Toyota forklift 5fbe15, which has problems with the left engine, since that does not work correctly...
If both are connected do not respond correctly...
I did not mark code can help me I have no manual... or diagrams
Tm 20 clark forklift error code -46 what does it
sounds like the #1 rectifier is shorted or the insulator gasket is shorted through -also the 1A contactor may be welded shut -usually caused by a weak battery or running a discharged battery too long. -Troy from A-Lift Services
3answers
Top Clark Electrical Supplies Experts
Aron
Don A
Don A
Simon Atkinson
Simon Atkinson
Are you a Clark Electrical Supply Expert? Answer questions, earn points and help others
