Car Audio & Video Logo
Posted on Oct 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Speaker removal on 2005 explorer sportrac ? getting the grill off the front door and speaker removal
Anonymous
Level 2:
Sniper:
  • Expert 69 Answers
  • Posted on Oct 05, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
69
Questions
0
Helped
45533
Points
233
I have attached a link with a how-to that has pictures so that you can get a better idea.
1. remove the window/lock switch panel by pulling upward at the front of the switch(held in by clips)careful not to break the tab towards the rear(see pic) unplug and remove
2. remove screw behind that panel
3. remove trim around the door handle, and screw behind that panel.
4. remove 2 screws at the bottom of the door panel
5. then pull straight up and towards you in one motion
http://www.explorerforum.com/forums//showthread.php?t=192049
hope this helps
How to remove door panel on 2014 Buick Verano
Remove the two screws retaining the sail panel/speaker grille assembly and remove the panel/grille from the door. Remove the three screws retaining the front door trim panel to the front door.
Need instructions to replace the passenger side mirror and the driver side tail light on a 1999 Ford Taurus 4-door sedan. Thank you, Gary S.
Section 01-09: Mirrors, Rear View 1999 Taurus/Sable Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 06/25/1998 Mirror, Power-Outside Rear View Removal
  1. Disconnect battery ground cable (14301).
  1. Remove front door trim panel (23942). Refer to Section 01-05.
  1. Remove radio speaker grille from cover assembly by squeezing or pinching between thumb and index finger.
  1. Remove two screws from cover assembly.
  1. Disconnect outside rearview mirror wiring connector (C515-LH; C615-RH). Remove wiring guides as necessary.
  1. Remove three outside rear view mirror retaining nuts. Remove outside rear view mirror (17682) while guiding wiring and connector through hole in door.
Item Part Number Description 1 17682 Outside Rear View Mirror 2 N621906-S36 Nut (3 Req'd) 3 F8DB-17D699-
AAW Cover Assembly Rear Substrate-LH 3 F8DB-17D698-
AAW Cover Assembly Rear Substrate-RH 4 N808968 Screw 5 F8DB-18B984-
AAW Speaker Grille-Standard (No Badge)-LH 5 F8DB-18985-
AAW Speaker Grille-Standard (No Badge)-RH 5 F8DB-18K901-
BAW Speaker Grille-Mach-LH 5 F8DB-18978-
BAW Speaker Grille-Mach-RH 5 F8DB-238A35-
AAW Speaker Grille-Blank (No Speaker)-LH 5 F8DB-238A34-
AAW Speaker Grille-Blank (No Speaker)-RH A - Tighten to 6-8 Nm (54-70 lb-in) ------------------
Trim Panel, Door Front
Removal
  1. Remove cover behind inside door handle.
  1. Remove screw from bottom of pull cup retaining front door trim panel to front door (20124).
  1. Remove three screws retaining front door trim panel to front door.
  1. NOTE: Do not attempt to remove more than one pushpin at a time.
    Using Rotunda Windshield and Molding Trim Removal Kit 107-R0401 or equivalent, remove the door trim panel by pulling one door trim panel pushpin at a time from the inner door skin.
  1. Disconnect electrical connectors as necessary. Refer to Section 01-14A.
Installation
  1. Follow removal procedure in reverse order.
  1. Replace all pushpins with new pushpins (N808994-S).
Front Door Trim Panel
6helpful
How do i car door panels safely
  1. Remove the cover behind the inside door handle.
  2. Remove the screw from the bottom of the pull cup retaining the front door trim panel to the front door.
  3. Remove the two screws retaining the sail panel/speaker grille assembly and remove the panel/grille from the door.
  4. Remove the three screws retaining the front door trim panel to the front door.
  1. Use a suitable tool to remove the pushpins from the door.
  2. Carefully lift the door panel away from the door.
  3. Detach the electrical connectors as necessary and remove the panel from the door.
To install:
  1. Installation is the reverse of removal.
Door Panel
This procedure applies to both the front and rear door panels.
// // 0) preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i]; } ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 30; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog']; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC'; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data'; //]]> var _strTreeScrollHidName = 'ctl00_hidTreeScrollPos'; c17hydro_23.gif
Remove the cover from behind the inside door handle by gently pulling it out to release the retaining tabs
Remove the pull cup retaining screw cover and...
... remove the retaining screw from the cup and lift the cup straight up out of the door panel
Remove the two sail panel/speaker grille retaining screws and...
... remove the panel/grille from the door
The door panel is retained to the door by 11 retaining clips
Carefully lift the door panel off of the door and...
... detach the electrical connectors from the switches and remove the panel from the vehicle
3helpful
How do you replace the regulator for the power window on the 2002 ford explorer
Regulator - Power Windows - Front Door
  1. Remove the front door trim panel as follows:
    1. Remove the front door handle bezel.
    2. Remove the front door window/lock control switch bezel.
    3. Disconnect the window/lock control switch electrical connectors.
    4. Remove the 3 front door trim panel screws.
      CAUTION To avoid damaging the trim panel, do not pull directly outward to carry out this step.
    5. Lift the door trim panel by pulling directly upward on the armrest to disengage the panel clips.
    6. Remove the exterior mirror control switch from the front door trim panel.
  2. Remove the front door speaker.
  3. Remove the interior molding.
  4. Disconnect the door lock actuating rod at the door handle assembly:
    1. Release the door lock actuating rod clip.
    2. Position the door lock actuating rod aside.
  5. Remove the front door weather shield.
    CAUTION Make sure the holes in the glass bracket do not become enlarged during the rivet removal process. If the holes become enlarged, the new rivets may become loose, resulting in clicking noise concern.
    NOTE Some vehicles may use rivets to attach the window glass to the window regulator assembly. Use a 4.5 mm (0.1772 in) drill bit to drill out the glass-to-regulator rivets.
  6. Remove the 2 front door window glass-to-regulator bolts or rivets.
  7. Position the front door window glass as necessary to access the front door window glass-to-regulator bolts or rivets.
  8. Secure the front door glass in the full up position with tape.
  9. Disconnect the window regulator motor electrical connector.
  10. Remove the 4 window regulator assembly nuts.
  11. Remove the window regulator assembly.
    Fig. Exploded view of the front door and power window components-2005 Explorer and Mountaineer
To install:
  1. Position the window regulator assembly.
  2. Install the 4 window regulator assembly nuts. Tighten to 89 inch lbs. (10 Nm).
  3. Connect the window regulator motor electrical connector.
  4. Remove the tape securing the front door glass in the full up position.
  5. Position the front door window glass as necessary to access the front door window glass-to-regulator bolts or rivets. Install the bolt and tighten the bolts to 62 inch lbs. (7 Nm), or install new rivets.
  6. Install the front door weather shield.
  7. Connect the door lock actuating rod at the door handle assembly:
    1. Position the door lock actuating rod into proper location.
    2. Attach the door lock actuating rod clip.
  8. Install the interior molding.
  9. Install the front door speaker.
  10. Install the front door trim panel as follows:
    1. Install the exterior mirror control switch from the front door trim panel.
    2. Position the door trim panel onto the armrest to engage the panel clips.
    3. Install the 3 front door trim panel screws.
    4. Connect the window/lock control switch electrical connectors.
    5. Install the front door window/lock control switch bezel.
    6. Install the front door handle bezel.
  1. Raise the front door window glass to the full up position.
  2. Remove the interior door handle.
  3. Support the front door window glass.
  4. Disconnect the front door window regulator motor electrical connector.
  5. Remove the equalizer bracket nuts.
    Fig. Remove the equalizer bracket nuts-2005 Explorer Sport-Trac
  6. Remove the front door window regulator by removing the rivets and nuts.
  7. Remove the front door window regulator motor retaining bolts and then remove the motor.
    Fig. Remove the front door window regulator motor retaining bolts and then remove the motor-2005 Explorer Sport-Trac
To install:
  1. Installation is the reverse of the removal procedure.
  2. Tighten the regulator motor mounting bolts to 8 ft. lbs. (11 Nm).
Hope this help (remember rated and comment this).
2helpful
How do you change the front speakers on a renault clio grande 1999 with electric windows. not sure on how the front grill for speaker is removed.
the grill is fixed to the door trim .take off door trim carefully.speaker/s are fixed to door frame simply take out/swop over speaker make sure they are fixed securely/dont vibrate....
How to replace front speakers in a daewoo leganza 02
You will need to either remove the door card or the speaker grill on the door card. To do this you will need a set of thin nose pliers for removing door clips, a flat head screw driver and a phillips screw driver for any cross head screws. Use the flat head screw driver to pop the grill off, if the grill is not removeable you will have to take the whole door card off. To do this you need to remove the electric windows panel as well as the door handle and lock panel, from their disconnect them from their harnesses. Then remove all clips and screws holding the panel in place. The door card should come free without too much effort, pulling upwards and away from the window. Unscrew the old speakers and disconnect the wires from them. Wire your new speaker to the same wire configuration as the old one. Screw it in. Place the door card back on and then plug the harnesses back in and place the door lock and window locking panels back in place. Do the same for the other door.
A professional installation will cost about $80 I think, I did my door speakers on my car and all I had to do was pop out the grill so it was easier than I expected.
Where is the O2 sensor on a 2005 Explorer Sportrac?
the o2 sensor is always located in the exhaust sys. usually near the manifold Note some vehicles have 2 sensors on located near the cat. converter
7helpful
Replace speakers on Ford Explorer Sport Trac
The front and rear door panels must be removed. The interior door handle will have to be removed, and the power window switch will also have be removed. This is held in by metal clips that secure it to the door panel. Do not be afraid to use a little force to get under the switch panel, and pry it from the door panel. Once you have all accessories off of the door panel, look for what may appear to be "plugs" in the door panel. These may conceal the presence of a screw. Also, check around the interior door pull for screws or "plugs". When this is done, use a medium to large screwdriver, or a trim removal tool, and start prying the door panel away from the door. Start at the bottom, and work your way around the door, until you get about 2-3 inches from the top of the panel where it meets the window. When you are at this point front and rear, simply lift up on the door panel, and it should come off easily. Once the panel is removed, you will easily find the speakers.
Replacing front door speakers
You need to pull the door panel to get to the speaker. It is bolted to the door shell, not the door panel.
Replacing front and rear speakers in a 1999 Mazda Protege
Whats the problem?
Back - Remove speaker grill, unscrew, climb in trunk, unplug - remove.
Front - Remove speaker grill, unscrew, pull out, unplug. If you have problems remove window winders and door skins
Top House Brand Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a House Brand Car Audio and Video Expert? Answer questions, earn points and help others
