Question about Dishwashers
Soap dispencer not opening. Feels like spring broke
  • 630 Answers
Should be easy to check the spring. When the door is open does the dispenser door spring back? If not it may just be that the spring has come loose. Disconnect the power. Most dishwashers have screws down the door sides to remove the front panel. Gently remove it and check the spring hasn't just come off the dispenser
Posted on Oct 03, 2009
SOURCE:
Why does my dishwasher most of the time not desovle the dish soap
make sure when you load it that nothing is stopping the soap door from opening all the way,, most common mistake is loading a cutting board or tray in the front of the lower rack
Nov 20, 2015 | Frigidaire Dishwashers
My kenmore he2 wont dispence the soap in the soap dispencer
Evening to you
Allow the washer to start a cycle and have the dispenser drawer ajar and observe through which dispenser the water goes.
Does the first stream go through the pre-wash dispencer,secondly notice where the main stream goes and lastly where the softener would go. If this can help you in any way just put use the dispencers as fits the washing.
goodluck
Kolbrun
Feb 26, 2012 | Kenmore HE2 Washing Machines
The soap dose not dispence
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) Maytag dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it
Oct 20, 2010 | Maytag MDB3100 Dishwasher
Soap dispencer does not open during operation
make sure the dispencer is clean from any kind of build up,or simply change out the dispencer
Mar 13, 2010 | Dishwashers
Softner in detergent drawer dispence at the wrong time
Take off the top of the front loader, topfrontleft is the dispenser, there is a movable part that was incrusted and unablble to freely move, clean off parts, little water will do, the movavable piece should move back to the roman numeral one, it is spring loaded, put top back on, done.
Dec 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The soap dispenser is not dispensing all of the soap (not overloaded)and fabric softener is not dispensng at all
dispencer cam could have come off, broken spring, bad disp motor, control not sending power to motor,top must come off to exspose
Dec 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Soap dispencer won' t dispence soap
My Bosch intergreted dishwasher is only 3 years old. For the past year, the dishwasher dispenser refuses to open on the second cycle. We have had the repair man here 3 times, and each time he says it's fixed,but it clearly is not. Does anyone know what to do about this??
Barbara Berger
Sep 30, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Soap door doesn't open
remove the door panel and replace the wax motor on the dispencer
May 22, 2008 | Whirlpool 24 in. DP840D Free-standing...
Lg tromm soap dispencer won't open
nothing to lock it fully closed......pull harder!
Jul 21, 2007 | LG WM2077CW Laundry XL Front Load...
Dishwashers Logo
Top Dishwashers Experts
Marvin
Marvin
