Xerox WorkCentre M123 Copier Logo
Posted on Oct 03, 2009
How to solve error of fuji xerox document centre 551. system fault 006-372
  • Gilbert Gonzalez May 11, 2010
    Does this error code come up when you insert a copy in the document handler when you press start button? If you power on and off the machine does this error code come on right away? Does the error code come up if the document is fed in partially?
Abdulasis Salaeh
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 21, 2014
Abdulasis Salaeh
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1515
Points
How to solve error code 012-284 fuji xerox ap-II 6000
3 Related Answers
Anonymous
  • 53 Answers
  • Posted on Aug 20, 2008
SOURCE: fuji xerox document centre C250
Sorry, what do you mean by "setting and pwd?"
Xeroxrep
  • 33 Answers
  • Posted on Sep 08, 2010
SOURCE: for document centre c250 fuji
Defective IIt/IPS board. Is very expensive. Call you local Xerox service number and ask them for part number 160K99811 and how much it would cost to get it fixed.
Anonymous
  • 2072 Answers
  • Posted on Oct 25, 2010
SOURCE: Xerox Docucolor 3535 fault code 006-372
That is a problem with the laser or ROS polygon mirror motor.
It most likley has failed.
Google a business called The Parts Drop, call and ask for Britt.
They can help you parts wise. Its not real difficult to replace.
1helpful
2answers
Model 560. What does error code 062-395 indicate?
http://www.manuals365.com/swf/fuji+xerox/ag-c560p_c550p.html?page=207
2answers
Xerox 550 fault code 045-315 how to solve this error code please give some technics
Error Codes and Support
Web page above states:
Error Description: Drive Logic Fail Solution: 1.Recycle your printer 2.Check all connections to the Engine Control Board 3.Make sure the correct firmware is installed. 4.If the error continues replace, the Engine Control Board (MCU PWB)
Manual for free download at link below:
Fuji Xerox Color 550 Administrator Manual Page 205
1helpful
Fuji xerox document centre 350 manual to download?
The User's Guide for the Document Centre 350 is available from the product support page. There are two files (one for the scanner and one for the printer). See http://onlinesupport.fujixerox.com/processDriverForm.do?ctry_code=TW&lang_code=en&d_lang=en&corp_pid=DC350&rts=null&model=Document+Centre+350&type_id=5&oslist=Windows+95&lang_list=en and the Documentation tab. The drivers are available for supported OS versions on the Drivers tab.
I hope this helps.
3helpful
For document centre c250 fuji xerox: error code 062-380 or error code 062-386
3helpful
Xerox Work Centre C2424 System Error
Hi there
I found some thing maybe do for you it may not be rhe right code you have at this moment but it come in handy for you.
31,004.40:6909: it's a mechanical initialization jam error. Pull out the paper tray to make sure it doesn't have a jam. Try also to manually feed some heavy paper or card stock through the printer to make sure the sensor in the preheater isn't stuck.
39,002.40 : DRAM test failure.
39,012.40:56208: "Cycle the power" and if that does not work replace the document feeder.
39,012.41: Document Feeder Optical Failure. Replace the document feeder.
4,0XX.6x: Process Control Software Fault.
· Reset NVRAM and then retest.
· Ensure ground integrity for the system
· Replace the EEPROM chip.
· Reboot the system.
· From the System Setup menu, go to "Information", "Troubleshooting"
· Service Tools menu.
· With the cursor at the top of the Service Tools menu, press both the Up Arrow
· and Down Arrow buttons to display the Hidden Service menu.
· Reset NVRAM is in there.
Also may be handy is this.
4,0XX.6x Process Control Software Fault
Error 04,041.66
Solution 1:
a. Reset NVRAM and then retest.
b. Ensure ground integrity for the system.
c. Replace the EEPROM chip.
d. Reboot the system.
1. From the System Setup menu, go to Information --> Troubleshooting -->
Service Tools menu.
2. With the cursor at the top of the Service Tools menu, press both the Up Arrow and Down Arrow buttons to display the Hidden Service menu.
3. Reset NVRAM is in there
Solution 2:
1. Turn the system power ON.
2. Wait for the Xerox logo to begin moving across the display.
3. Before the logo is centered on the display, press and hold the Back and Info buttons on the control panel.
4. Hold both buttons until the display reads “Beginning Service Mode Initialization”. Release the buttons and the system reboots into service mode with the Service Diagnostics menu displayed. Hope it will help you in some way of finding the fault. Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
My Xerox Document Centre 265ST just stopped working and a message: Copier is not available Printer Fault please call for assistance I cannot access tools or anything else.
turn it off completely unplug it. open up all doors and trays....turn it on with everything open if you still get the error you are going to have to call in a tech if it starts up . start closing things till you get to when that errror comes up then repost and ill look up an answer for you. i work for xerox
5helpful
2answers
Fuji xerox document centre C250
Press machine log in button, enter 11111 confirm, this will take you to sys admin mode, from here you can navigate into sys settings to configure network,copy and fax defaults, and also auditron admin if this is the password mentioned, if the 11111 password has been changed hold the zero button for a few seconds then press start while still holding zero enter 6789 to get into diagnostics, and you can navigate through to the above settings caution be careful what you change in this mode.
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
