Re: whomanufactures the cars tv model number c1310atv
Some Unkown company Disney contracted,no universal code.Must buy exact remote or compatible one.Try this website have it.1-800-Remotes Factory Original.
Universal remote codes can vary depending on the brand and model of the remote control you are using. TCL TVs are often compatible with various universal remotes, and you can typically find the codes in the remote's manual or on the manufacturer's website. However, if you don't have access to the manual, you can try the following steps to find the code:
1. **Automatic Code Search:**
- Turn on your TCL TV.
- Point the universal remote at the TV.
- Press and hold the "Code Search" or "Setup" button on the remote until the LED light turns on.
- Press the "TV" (or another applicable) button on the remote.
- The LED light should blink once and then stay solid.
- Press the "Power" button repeatedly until the TV turns off.
- Once the TV turns off, press the "Enter" or "OK" button on the remote to save the code.
2. **Manual Code Entry:**
- Find the code list that came with your universal remote or check the manufacturer's website for a list of codes.
- Enter the first code for TCL TVs from the list using the number buttons on the remote.
- If the LED light blinks, check if the TV responds to the remote (try turning it off and on).
- If the TV does not respond, repeat the process with the next code until you find the correct one.
3. **Manufacturer's Support:**
- Visit the website of the universal remote's manufacturer and check if they provide code lists or support for TCL TVs.
- You may find an online tool or database to help you find the correct code for your TCL TV model.
Remember that not all universal remotes are compatible with all TV models, so it may take some trial and error to find the correct code. If none of the codes work, you may need to contact the manufacturer of your universal remote for further assistance.
The 4-digit code to program a universal remote to work with a RCA LED32B30RQ TV model is likely to be one of the following:
11447 11758 11442
To program the universal remote to work with the RCA LED32B30RQ TV:
Turn on the TV
Press and hold the "Setup" button on the universal remote until the "TV" button blinks twice.
Press the "TV" button on the remote.
Enter the 4-digit code for your TV using the number buttons on the remote.
Press the "Power" button on the remote. The TV should turn off.
Press the "Setup" button again to lock in the code.
If the TV does not turn off after entering the code, please try the other codes listed above. If none of the codes work, you may need to refer to the universal remote manual or contact the manufacturer for further assistance.
Note: The method to program the universal remote may vary depending on the remote brand and model
May 9, 2014 - Need codes for universal remote model number lm-1079. Asked by paula young on ... 1 how to set code for tv from lm_1079. Was this answer ...Missing: broksonic
Each maker of universal programmable remotes has their own set of numbers for the various codes. Procsan might be 123 in URCs code list, but cold be 987654 in Memorex.
You need to start with the make and model of universal remote that you are using. Then find the code that that brand (the remote maker) uses for the make of TV that you have.
Unknown small company make this tv for the Disney Corporation.But u can buy the original remote for this tv.Try website like Remotes.com to buy an original remote.
Go to website of the universal remote control manufacturer and use the code finder tool that most offer. You will need your tv manufaturer name and model number as well as the model number of your remote.
Philips Magnavox makes the remote. Not sure about the model #, but you can get to the audio/video or DVD by scrolling through using the channel buttons on the unit itself. I have also been successful with a universal remote with the exception the channel up and down would not fuction correctly, but direct entry did, as well as the source select. Hope this helps.
Each universal remote manufacturer has a specific list of codes that only pertains to thier remotes for each brand TV. I will need to know the make and model number of your remote to help you. The model number if not on the remote should be inside the battery compartment
