Question about RC Toys
Yiboo AH-64 3D RC Mini Apache Helicopter, out of the box, charges, but will not do anything, channel C
Mine worked good for 3 days then died..Top blades wont spin.. It worked really well. The guy at (as seen on TV) shop that sold it to me actually seemed to tell me "Do not buy this!" But I bought it anyway at his word that I cannot bring it back no matter what after 24 hours..spent 90 bucks on this junk and there is NO SOLUTION
Posted on Jan 21, 2010
There is a small set screw on the bottom gear that holds in the upper shaft. You can see these gears through the belly of the helicopter. I had the same problem with the top rotors, and had to go in and re-insert the rotor shaft and tighten the set screw. I applied locktite to the threads to prevent it from backing out. It works now, but one problem I notice is that there must have been a spacer bushing between the two gear wheels. Without the bushing, it will still fly, but I can feel some play in the upper shaft and wonder if over time that the counter spinning gear wheels will start to wear against eachother.
Posted on Feb 10, 2010
Same thing happing with mind low motor go's bad and i cannot find replacment went bad after fling 4 times
Posted on Jan 09, 2010
Bottom blade doesn't spin
Posted on Jan 02, 2010
Same problem with me as well with the Apache from Yiboo..the rotor motor went bad
SOURCE:
Syma S109g Apache Ah-64 3.5-channels Mini Indoor Helicopter will not charge; the light will keep being red on the USB
Try bringing it to your local electronics store. It might be the connection, or in could be another electrical problem.
Jan 29, 2013 | Syma S109g Apache Ah-64 3.5-channels Mini...
X107 Mini helicopter does not seem to be taking a charge from USB port on computer. ran coptor for about 2 weeks following recharging instructions... rest, recharge of heli in "off"...
Hi, My X107 MINI HELICOPTER does not receive transmit anymore. It was working fine before. It only flys if I hold the remote control right next to the sensor. If I move it away it loses transmit. Both units have full power. How do I solve this problem.
Jan 27, 2011 | Cobra Electronics Cobra RC 3 Channel Mini...
Rc 3 channel apache helicopter how to replace balance bar without the tool kit provided
Cut the balance bar off until the pins are exposed. Use some pliers and squeeze the pin out and then put the new balance bar back on and put the pin back in.
I did it this way without the tool kit, my balance bar was already broken so it wasn't an issue to cut it. It worked for me, I am flying it right now.
Jan 02, 2011 | Apache RC Mini Helicopter AH-64
I crashed my Apache onto a table and when I try to fly it, It keeps spinning out of control. To my knowledge I don't see anything broken. It spins to the right. Please help! thanks!!!
It sounds like your tail rotor is acting up or missing. It keeps your Helicopter from flying in circles.
http://www.start-flying.com/new%20site/heli1.htm
Oct 04, 2010 | Apache RC Mini Helicopter AH-64
Remove and replace balance bar?
Were you able to find a replacement balance bar? I broke mine and can't find one? Thanks!
Apr 18, 2010 | Apache RC Mini Helicopter AH-64
How do you charge the mini ah 64
Turn the remote over and look for the sliding door on the back bottom right (it has a circle and some arrows on it, push in the direction of the arrows) the cable is under this door. Then connect that cable to the helicopter by plugging it into the white slot next to the on/off switch.
Dec 25, 2009 | SYMA Toys industrial SYMA 3 Channel S012...
I have an apache 3 channel helicopter.the top blades no longer spin so the helicopter just spins clockwise very quickly
Same problem I had. There are two motors. One to spin the top blade and a second to spin the bottom. My motor was defective out of the box to spin the top blade. Very poor quality as my AH 64 had a bad circuit board. I had to take parts from one to fix the other.
Sep 04, 2009 | Apache RC Mini Helicopter AH-64
Toys Logo
4,329 people viewed this question
Top RC Toys Experts
Tom Chichester
Kevin K.
Brett Duxbury
Brett Duxbury
Are you a RC Toy Expert? Answer questions, earn points and help others
